Poly Plantronics Blackwire C5210 USB-C Wired Headset
Quicklinx: DY1KWS00 Mfr#: 207587-01
The Blackwire 5200 Series fits your busy workday. Easy to use, USB-C and 3.5 mm connectivity lets you work on a variety of devices. And it's so comfortable, you'll be able to wear it all day. The Blackwire 5200 Series-connect, work, seamlessly.
  • All-day comfort and universal connectivity
    When you need to wear a headset all day, the Blackwire 5200 Series has you covered in the utmost of comfort. Ergonomically designed, it's comfortable enough to wear all day, on your longest calls.
  • Astounding audio
    Noise-canceling mic with flexible boom, microphone meets Near Talker specifications.
  • Outstanding audio quality for better productivity
    Today's workplace can be noisy and filled with distractions. With the Blackwire 5200 Series, you'll be able to hear and be heard more clearly, enjoy conversation privacy and be more productive. That's because soft, conforming ear cushions provide passive noise canceling, while a precisely tuned microphone masks nearby conversations.
  • A headset that works the way you do
    Adjust the headset to fit the way you work. Dedicated, customizable mute settings allow you to take calls confidently, ensuring you're always heard. Set the language for voice alerts, and you're in even greater control of your conversation.
Poly Blackwire 5210 - headset
Headset - wired - 3.5 mm jack, USB-C
Recommended Use
Portable electronics, computer - communication
Additional Functions
DSP
Headphones Form Factor
On-ear
Wired
Sound Output Mode
Mono
Audio Specifications
Frequency Response 20 - 20000 Hz
Microphone
Boom
Controls
Mute, volume, answer/end
Software Certification
Certified for Microsoft Teams
Series
5200 Series
DSP
Dimensions & Weight Details
125.4 g
Headband Material
Cushioned metal
Earpad Material
Leatherette
Recommended Use
Voice alerts
Protection
Hearing protection
Audio Output
On-ear
Wired
Sound Output Mode
Mono
Frequency Response
20 - 20000 Hz
In-Cord Volume Control
SoundGuard Technology
Microphone
Boom
Frequency Response
100 - 8000 Hz
Remote Control
Controls
Connector Type
USB (USB Type-C) , Headset (mini-phone stereo 3.5 mm)
Carrying case
Cable Details
Headset cable
