Poly Plantronics Blackwire C3220 Usb-C
Quicklinx: FX70WS00 Mfr#: 209749-201
The Blackwire 3200 Series provides a best-in-class audio experience in a headset that's built for enterprise needs. Even better, people want to wear it - so your investment pays off. With a sleek design and flexible microphone boom for a customizable fit, what's not to love? Plus, it sounds as good as it looks. Enjoy the high-quality audio you expect from Poly.
  • Superior audio clarity
    Experience exceptional audio quality with a frequency response range of 20 - 20,000 Hz for the headphones, ensuring every note and word is crystal clear. The microphone's 100 - 10,000 Hz frequency response captures your voice with precision, making every call and recording sound professional.
  • Comfortable design
    Designed with on-ear headphones, the Poly Blackwire C3220 provides a comfortable fit for long hours of use, whether you're on calls or listening to music. The boom-mounted microphone allows for adjustable positioning, ensuring your voice is always heard clearly.
  • Enhanced call control
    Equipped with intuitive controls for answer/end, hold, mute, redial, and volume adjustments, this headset gives you complete command over your audio experience during calls. This seamless integration makes communication more efficient and user-friendly.
  • Robust protection
    Featuring SoundGuard Technology, the Poly Blackwire C3220 offers hearing protection by managing sound levels, ensuring your ears are safeguarded against audio spikes. This feature is essential for maintaining long-term hearing health.
  • Universal compatibility
    With USB connectivity, the Poly Blackwire C3220 is versatile and ready to use out of the box with both Mac and Windows computers. This broad compatibility ensures a hassle-free setup for all your communication and multimedia needs.
Poly Blackwire C3220 - headset
Headset - wired - USB-C
Compatibility
Mac, Windows
Recommended Use
Portable electronics, computer - communication
Headphones Form Factor
On-ear
Wired
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 20000 Hz
Noise Isolating
Microphone
Boom
Controls
Mute, volume, answer/end, hold, redial
Series
3200 Series
Compatibility
Mac, Windows
Dimensions & Weight Details
118 g
Earpad Material
Leatherette
Recommended Use
Protection
Hearing protection
Audio Output
On-ear
Wired
Sound Output Mode
Stereo
Noise Isolating
Frequency Response
20 - 20000 Hz
In-Cord Volume Control
Microphone
Boom
Headset microphone
Frequency Response
100 - 10000 Hz
Remote Control
Controls
Connector Type
USB (USB Type-C)
Carrying case
Cable Details
USB-C cable
