The Blackwire 3200 Series provides a best-in-class audio experience in a headset that's built for enterprise needs. Even better, people want to wear it - so your investment pays off. With a sleek design and flexible microphone boom for a customizable fit, what's not to love? Plus, it sounds as good as it looks. Enjoy the high-quality audio you expect from Poly.
Superior audio clarity
Experience exceptional audio quality with a frequency response range of 20 - 20,000 Hz for the headphones, ensuring every note and word is crystal clear. The microphone's 100 - 10,000 Hz frequency response captures your voice with precision, making every call and recording sound professional. -
Comfortable design
Designed with on-ear headphones, the Poly Blackwire C3220 provides a comfortable fit for long hours of use, whether you're on calls or listening to music. The boom-mounted microphone allows for adjustable positioning, ensuring your voice is always heard clearly. -
Enhanced call control
Equipped with intuitive controls for answer/end, hold, mute, redial, and volume adjustments, this headset gives you complete command over your audio experience during calls. This seamless integration makes communication more efficient and user-friendly. -
Robust protection
Featuring SoundGuard Technology, the Poly Blackwire C3220 offers hearing protection by managing sound levels, ensuring your ears are safeguarded against audio spikes. This feature is essential for maintaining long-term hearing health. -
Universal compatibility
With USB connectivity, the Poly Blackwire C3220 is versatile and ready to use out of the box with both Mac and Windows computers. This broad compatibility ensures a hassle-free setup for all your communication and multimedia needs.
- Poly Blackwire C3220 - headset
- Product Type
- Headset - wired - USB-A
- Compatibility
- Mac, Windows
- Recommended Use
- Computer - communication
- Headphones Form Factor
- On-ear
- Connectivity Technology
- Wired
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 20 - 20000 Hz
- Microphone
- Boom
- Controls
- Mute, volume, answer/end, hold, redial
- Environmental Standards
- TCO Certified Headsets 9
- Product Type
- Series
- 3200 Series
- Compatibility
- Mac, Windows
- Dimensions & Weight Details
- 118 g
- Recommended Use
- Noise reduction
- Protection
- Hearing protection
Audio Output
- On-ear
- Wired
- Sound Output Mode
- Stereo
- 20 - 20000 Hz
- In-Cord Volume Control
- SoundGuard Technology
Microphone
- Boom
- 100 - 10000 Hz
Remote Control
- Controls
- Connector Type
- USB (4 PIN USB Type A)
- Cable Details
- USB cable
Sustainability Information
- TCO Certified
