The Plantronics Blackwire 3200 Series headsets are durable, comfortable, and easy to deploy. Blackwire 3200 Series with Plantronics signature audio provides excellent features at a price you can afford.
Superior audio quality
Offering PC wideband, a noise-canceling microphone and hi-fi stereo sound, Blackwire 3200 Series headsets provide a signature truly outstanding audio experience - ideal for voice, music and multimedia. The dynamic EQ feature optimizes your voice quality when you're on a call and automatically adjusts the EQ settings when you're listening to music or multimedia. -
Connectivity options
Ideal for knowledge workers who need a solution for managing calls on their PC, mobile phone or tablet. Blackwire 3200 Series offers the comfort and durability of corded combined with flexibility - at an entry-level price point. You can manage calls from your PC or tablet with standard USB or USB-C connectivity. The C3215 models offer a 3.5 mm connection option for your wireless device. -
Comfort and portability
Enjoy the security of a comfortable fit. A lightweight metal headband offers durability and a custom fit. Leatherette ear cushions fold flat for easy portability.
- Poly Blackwire C3215 - headset
- Product Type
- Headset - wired - 3.5 mm jack, USB-C
- Compatibility
- Mac, Windows
- Recommended Use
- Portable electronics, computer - communication
- Headphones Form Factor
- On-ear
- Connectivity Technology
- Wired
- Sound Output Mode
- Mono
- Audio Specifications
- Frequency Response 20 - 20000 Hz
- Microphone
- Boom
- Controls
- Mute, volume, answer/end, hold, redial
- Product Type
- Series
- 3200 Series
- Compatibility
- Mac, Windows
- Dimensions & Weight Details
- 96 g
- Earpad Material
- Leatherette
- Recommended Use
- Protection
- Hearing protection
Audio Output
- On-ear
- Wired
- Sound Output Mode
- Mono
- 20 - 20000 Hz
- In-Cord Volume Control
- SoundGuard Technology
Microphone
- Boom
- Form Factor
- Headset microphone
- 100 - 10000 Hz
Remote Control
- Controls
- Connector Type
- USB (USB Type-C) , Headset (mini-phone stereo 3.5 mm 4-pole)
- Included Accessories
- Carrying case
- Cable Details
- USB-C cable - detachable , Headset cable
