With its boomless corded headset design, hi-fi stereo sound, and all-day comfort, Plantronics Blackwire 7225 helps makes work more productive in open office environments - meeting the needs of office professionals and IT alike.
Distraction-free productivity
Today's workplace environments are usually noisy with frequent interruptions. Blackwire 7225 delivers active noise canceling (ANC), minimizing background noise so that you can tune out distractions and tune into conversations. -
A corded, boomless design
Blackwire 7225 features a pioneering boomless headset design, with hi-fi stereo sound and either USB-A or USB-C connectivity. Lightweight and stylish, it's comfortable and delivers Plantronics signature sound and crystal-clear audio - whether you're listening to media or collaborating on voice or video calls. -
Designed for the way you work
Blackwire 7225 makes switching from concentration to collaboration on the spot easy. One-touch call and media controls are easily accessible. Dynamic mute alert lets you know if you are talking while muted, which helps make sure your colleagues catch your every word.
- Poly Blackwire 7225 - headset
- Product Type
- Headset - wired - USB
- Recommended Use
- Computer
- Black
- Headphones Form Factor
- On-ear
- Connectivity Technology
- Wired
- Audio Specifications
- Frequency Response 20 - 20000 Hz - Sensitivity 127 dB
- Impedance
- 32 Ohm
- Active Noise Canceling
- Microphone Operation Mode
- Omni-directional
- Controls
- Mute, volume, answer/end, play/pause, next/previous track
- Software Certification
- Certified for Microsoft Teams
- 2-year warranty
- Product Type
- 155 g
- Black
- Recommended Use
- Computer
Audio Output
- On-ear
- Wired
- 20 - 20000 Hz
- Sensitivity
- 127 dB
- Impedance
- 32 Ohm
- Diaphragm
- 32 mm
- Adjustable Headband
Microphone
- Form Factor
- Built-in
- Omni-directional
- Sensitivity
- -26 dBFS
- 100 - 10000 Hz
Remote Control
- Controls
- Connector Type
- Headset (4 PIN USB Type A)
- Included Accessories
- Carrying case
- Cable Details
- Headset cable
- Limited warranty - 2 years
