Poly Plantronics Backbeat Fit 500 Wireless On-Ear Sport Headphones Black
Quicklinx: DFHKWS00 Mfr#: 210704-99
From locker room to lecture hall, you're always on the move. Don't let cords slow you down. The BackBeat FIT 505 wireless sport headphones with sweat-resistant nano-coating technology by P2i gives you the freedom to listen all day long with long hours of power on a single charge. Its deep, rich sound will carry you through your toughest reps and longest study sessions, while its lightweight design makes for comfortable wearing all day. The BackBeat FIT 505 - experience wireless.
  • As unstoppable as you are
    When it comes to your workout, nothing gets in your way. Stay focused and distraction-free with wireless sport headphones that stay comfortably in place. BackBeat FIT provides superior stability with a behind-the-ear design and comfortable eartip. The only reminder that you're wearing them is the rich sound of your favourite playlist or podcast pushing you to your next personal best.
  • Engineered for sport
    Ready to go the extra mile or ten? Flexible and durable, BackBeat FIT pushes you further, withstanding the rain or a rinse under the tap with a waterproof design that meets the IP57 rating and an additional sweatproof nano coating. And whether you wear them running roadside or on the trail, the open eartip design lets you hear the sounds around you.
  • You never quit, neither should your headphones
    With up to eight hours of listening from a single charge, BackBeat FIT helps you power through a full week of workouts. Subtle voice alerts let you know how much listening time you have left, and the 15-minute quick-charge provides an hour of play to get you through the day's challenge.
Poly - Plantronics Backbeat FIT 505 - headphones with mic
Headphones - Bluetooth - wireless
Recommended Use
Portable electronics
Headphones Form Factor
On-ear
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 4.1
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 50 - 20000 Hz
Impedance
32 ohm
Controls
Answer/end, play/pause, next/previous track
14.877 cm
17.155 cm
6.726 cm
155 g
Headband Material
Memory foam
Earpad Material
Memory foam
Recommended Use
Protection
Moisture-resistant, sweat-resistant
Max Operating Distance
10 m
Audio Output
On-ear
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 4.1
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Sound Output Mode
Stereo
Frequency Response
50 - 20000 Hz
Total Harmonic Distortion (THD)
<3%
Impedance
32 ohm
Diaphragm
40 mm
Microphone
Built-in
Remote Control
Controls
Wireless Link
Transmission Range
10 m
Cable Details
Micro-USB charge cable , Audio cable
Headphone battery rechargeable
Run Time (Up To)
18 hour(s)
Standby Time
480 hours
Recharge Time
1.5 hour(s)
