From locker room to lecture hall, you're always on the move. Don't let cords slow you down. The BackBeat FIT 505 wireless sport headphones with sweat-resistant nano-coating technology by P2i gives you the freedom to listen all day long with long hours of power on a single charge. Its deep, rich sound will carry you through your toughest reps and longest study sessions, while its lightweight design makes for comfortable wearing all day. The BackBeat FIT 505 - experience wireless.
As unstoppable as you are
When it comes to your workout, nothing gets in your way. Stay focused and distraction-free with wireless sport headphones that stay comfortably in place. BackBeat FIT provides superior stability with a behind-the-ear design and comfortable eartip. The only reminder that you're wearing them is the rich sound of your favourite playlist or podcast pushing you to your next personal best. -
Engineered for sport
Ready to go the extra mile or ten? Flexible and durable, BackBeat FIT pushes you further, withstanding the rain or a rinse under the tap with a waterproof design that meets the IP57 rating and an additional sweatproof nano coating. And whether you wear them running roadside or on the trail, the open eartip design lets you hear the sounds around you. -
You never quit, neither should your headphones
With up to eight hours of listening from a single charge, BackBeat FIT helps you power through a full week of workouts. Subtle voice alerts let you know how much listening time you have left, and the 15-minute quick-charge provides an hour of play to get you through the day's challenge.
- Poly - Plantronics Backbeat FIT 505 - headphones with mic
- Product Type
- Headphones - Bluetooth - wireless
- Recommended Use
- Portable electronics
- Black
- Headphones Form Factor
- On-ear
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Bluetooth Version
- Bluetooth 4.1
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 50 - 20000 Hz
- Impedance
- 32 ohm
- Controls
- Answer/end, play/pause, next/previous track
- Product Type
- 14.877 cm
- 17.155 cm
- 6.726 cm
- 155 g
- Black
- Headband Material
- Memory foam
- Earpad Material
- Memory foam
- Recommended Use
- Protection
- Moisture-resistant, sweat-resistant
- Max Operating Distance
- 10 m
Audio Output
- On-ear
- Wireless
- Bluetooth
- Bluetooth Version
- Bluetooth 4.1
- Bluetooth Profiles
- Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Sound Output Mode
- Stereo
- 50 - 20000 Hz
- Total Harmonic Distortion (THD)
- <3%
- Impedance
- 32 ohm
- Diaphragm
- 40 mm
Microphone
- Form Factor
- Built-in
Remote Control
- Controls
Wireless Link
- Transmission Range
- 10 m
- Cable Details
- Micro-USB charge cable , Audio cable
- Battery
- Headphone battery rechargeable
- Run Time (Up To)
- 18 hour(s)
- Standby Time
- 480 hours
- Recharge Time
- 1.5 hour(s)
