The Poly Studio P5 webcam ensures you look great on video calls at home, in the office, or wherever you're working. Quality camera optics are fine-tuned so you come across clearly with a powerful, professional-quality image.
Put your best foot forward on every call with optics specially designed for video conferencing. Gain confidence that you are clearly seen with brilliant colors designed to show you at your best. -
Low-light compensation
Don't let imperfect lighting deteriorate your image during a call. Automatic low-light compensation lets you look your best even in dim environments. -
Precise camera view
With people working from more places, background movement, clutter, and household members can detract from your calls. A narrow field of view keeps the focus on the conversation at hand rather than your surroundings. -
Pro-grade resolution
A grainy video feed can be distracting for colleagues. With 1080p resolution and a 4x digital zoom camera, you can be sure that your video is crystal clear. -
Directional microphone
You're heard clearly with a built-in directional microphone that focuses on your voice, not the noise around you.
 - Poly Studio P5 - webcam
 - Webcam
- Audio
 - Yes: built-in unidirectional microphone
- Camera Mount Type
 - Tripod mount
 - 3.7 cm x 3.4 cm x 6.2 cm
 - 68 g
- Connectivity Technology
 - Wired
- Camera
- Video Modes
 - 720p, 1080p
- Focus Adjustment
 - Automatic
 - USB 2.0
- Software Certification
 - Certified for Microsoft Teams, Zoom Certified
- Cables Included
 - USB cable - integrated - 1.3 m
 - ePTZ, privacy shutter, Low Light Compensation (LLC), adjustable monitor clamp, LED indicator, 80° diagonal field of view, Webcam Support (UVC), 50 Hz to 16 kHz microphone frequency response
 - 2-year warranty
- Environmental Parameters (operating)
 - 0 °C - 40 °C; 5 - 95% RH relative humidity
 - Webcam
- Audio Support
- Camera Mount Type
 - Tripod mount
 - Wired
 - 3.7 cm
 - 3.4 cm
 - 6.2 cm
 - 68 g
Camera
- Video Modes
 - 720p, 1080p
- Digital Zoom
 - 4
- Video Capture
 - 1920 x 1080 @ 30 fps , 1280 x 720 @ 30 fps
Lens Construction
- Focus Adjustment
 - Automatic
- Computer Interface
 - USB 2.0
- Ports
 - USB 2.0 - 4 pin USB Type A
- Included Accessories
 - Monitor mount
- Cables Included
 - Plug and Play
- OS Required
 - Windows 10, Windows 8.1, Apple MacOS X 10.7 or later
 - Limited warranty - 2 years
- Shipping Width
 - 10.2 cm
- Shipping Depth
 - 15.3 cm
- Shipping Height
 - 5.5 cm
- Shipping Weight
 - 185 g
 - 0 °C
 - 40 °C
- Relative Humidity (operating)
 - 5 - 95% RH
