Poly HP Poly Blackwire 3325 - headset - 3.5 mm jack, USB-C
Quicklinx: J4MLWS00 Mfr#: 8X221AA
Recommended Use: Computer, Portable electronics
Connectivity: Wired
£48.40 ex VAT
£58.08 inc VAT
Built for style with a sleek design that focuses on comfort and reliability. Poly signature audio quality so you know you will sound great. And intuitive and simple features so every user can connect to their preferred device simply and easily.
  • High-quality audio
    Makes collaboration easy with Poly signature audio quality and reliability.
  • Wearing style
    Hi-fi stereo wearing style for those who want a richer, more immersive experience.
  • Headset flexibility
    With professional voice quality and a customized fit, this fully adjustable headset has 180-degree pivoting speakers and a flexible microphone boom.
  • Long-lasting comfort
    Supports long-wearing comfort with a plush, padded headband and pillow soft ear cushions.
  • Connectivity options
    Enhanced connectivity for your devices: USB Type-C cord with tethered USB-A adapter for PC and 3.5 mm for mobile or tablet connectivity.
  • Optimized for communications platforms
    An IT manager's dream, this headset was created for communication and is optimized and certified to work with top virtual meeting providers.
Headset - wired - 3.5 mm jack, USB-C
Compatibility
Mac, Windows
Recommended Use
Computer, portable electronics
Headphones Form Factor
On-ear
Wired
Sound Output Mode
Stereo
Audio Specifications
Sensitivity 116 dB
Impedance
32 ohm
Microphone
Boom
Microphone Operation Mode
Omni-directional
Controls
Answer/end, mute, volume
Software Certification
UC certified
Series
Blackwire 3300 series
Compatibility
Mac, Windows
131 g
Earpad Material
Artificial leather
Recommended Use
Audio Output
On-ear
Wired
Sound Output Mode
Stereo
Sensitivity
116 dB
Impedance
32 ohm
Max Sound Pressure
118 dB
Diaphragm
32 mm
In-Cord Volume Control
Adjustable Headband
Dynamic EQ optimised
Microphone
Boom
Omni-directional
Sensitivity
-38 dB
Frequency Response
100 - 10000 Hz
Remote Control
Controls
Connector Type
USB (24 pin USB-C) , Headset (mini-phone 3.5mm)
USB-C to USB-A adapter
Supported Host Device OS
Windows 10, macOS
UC certified
J4ML Poly - USB adapter - 24 pin USB-C to USB In Stock £13.36
Recommended Use: Portable electronics
Connectivity: Wired
Brand: Poly
