HL10 handset lifter fits on your telephone, letting you answer calls with the touch of a button, conveniently and automatically takes your handset off hook.
- Poly HL 10 - handset lifter for phone
- Product Type
- Handset lifter
- Intended For
- Phone
- Product Material
- Plastic
- 10.2 cm x 7.3 cm x 4.3 cm
- 100 g
- Designed For
- SupraPlus Wireless CS361 with Voice Tube
- Product Type
- Handset lifter
- Intended For
- Phone
- Product Material
- Plastic
- 10.2 cm
- 7.3 cm
- 4.3 cm
- 100 g
- Designed For
- Poly - Plantronics SupraPlus Wireless CS361 with Voice Tube
