The Poly Y-Training Cable (6-pin) part # Poly 79694-11 or HP 85S09AA allows two headsets to operate with one amplifier for training/monitoring purposes. Both headsets can listen, but only one headset will have a live microphone. The other microphone is muted. The red toggle switch allows the supervisor to control which microphone is live and which is muted. This cable is TAA Compliant.
Efficient collaboration
The Y-type training cable design allows for simultaneous audio input, making it an ideal solution for collaborative environments where sharing audio sources is essential. -
Versatile connectivity
Designed as a headset splitter, this cable offers versatile connectivity options, enabling users to connect multiple headsets to a single audio source without compromising sound quality.
- Poly headset splitter
- Cable
- Headset splitter
- Y-type training cable
- Cable Type
- Headset splitter Y-type training cable
- Included Accessories
- Quick disconnect lock
- Shipping Width
- 13 cm
- Shipping Depth
- 21 cm
- Shipping Height
- 7 cm
- Shipping Weight
- 110 g
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
HLHY 049004 Condition: Damaged stock - Item is new but has packaging damage |
£3.12 |
Ref:
HLHY 051025 Condition: Customer return - item has been opened but is in excellent condition |
£15.18 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
