Plantronics QD to 3.5mm cable. Allows a Plantronics headset with a Quick Disconnect to connect to a phone with 3.5mm socket.
Effortless connectivity
The Poly headset cable is designed with a 3.5 mm audio jack on one end and a Quick Disconnect feature on the other, ensuring seamless connection to a wide range of devices without the need for multiple adapters. -
High-quality construction
Crafted for durability and long-lasting performance, this cable from HP Inc. stands up to the rigors of daily use, making it an ideal choice for both professional and personal environments.
Poly Headset Cable - 3.5mm Audio Jack to Quick Disconnect
