Poly Headset Cable - 3.5mm Audio Jack to Quick Disconnect
Quicklinx: HLQ7WS00 Mfr#: 920P8AA
£15.91 ex VAT
£19.09 inc VAT
Plantronics QD to 3.5mm cable. Allows a Plantronics headset with a Quick Disconnect to connect to a phone with 3.5mm socket.
  • Effortless connectivity
    The Poly headset cable is designed with a 3.5 mm audio jack on one end and a Quick Disconnect feature on the other, ensuring seamless connection to a wide range of devices without the need for multiple adapters.
  • High-quality construction
    Crafted for durability and long-lasting performance, this cable from HP Inc. stands up to the rigors of daily use, making it an ideal choice for both professional and personal environments.
Poly - mute switch for headset
Mute switch
Intended For
Headset
Mute switch
Intended For
Headset
Brand: Poly
