Poly EncorePro HW520D - headset - Quick Disconnect
Quicklinx: J45MWS00 Mfr#: 783P5AA
£105.92 ex VAT
£127.10 inc VAT
The EncorePro 500 Series smarter headsets let your employees take calls from home or office, regardless of how they connect to a PC. They're the first call center digital headsets to connect you to everything Teams has to offer, even while you're on a call. Hybrid working has never been easier.
  • Built-in Hold and Call Answer buttons
    Make every call easier with clear, built-in hold and call answer buttons.
  • Recessed buttons
    Eliminate button-pushing mistakes with recessed buttons that don't get accidently activated.
  • Single button for joint audio/video hold
    Enjoy worry-free privacy and peace of mind with a single button for joint audio and video hold.
Headset - wired - Quick Disconnect
Recommended Use
Computer
Headphones Form Factor
On-ear binaural
Wired
Audio Specifications
Frequency Response 20 - 10000 Hz
Signal-To-Noise Ratio
50 dB
Microphone
Boom
Microphone Operation Mode
Omni-directional
Microphone Noise Cancelling
Software Certification
Certified for Skype for Business
Series
EncorePro 500 series
11.1 cm
14.9 cm
6.7 cm
74 g
Earpad Material
Artificial leather
Recommended Use
Computer
290° rotatable microphone, boom mic length 135mm
Audio Output
On-ear binaural
Wired
Frequency Response
20 - 10000 Hz
50 dB
Diaphragm
5.6 mm
Microphone
Boom
Omni-directional
Sensitivity
40 dB
Sensitivity Margin
+/- 3dB
Frequency Response
20 - 16000 Hz
Noise Cancelling
Connector Type
Headset (Quick Disconnect)
Cable
Cable Length
78.5 cm
Supported Host Device OS
Windows, macOS
Shipping Width
13.78 cm
Shipping Depth
17.8 cm
Shipping Height
5.46 cm
Shipping Weight
180 g
J45M Poly DA75 Sound Card In Stock £26.52
J45M Poly DA85-M Sound Card In Stock £44.59
J45M Poly EncorePro HW510/520 Foam Ear Cushions In Stock £2.04
J45M Poly DA85 Headset Cable - USB-C to Quick Disconnect In Stock £43.35
J45M Poly HIS Adapter Cable In Stock £24.75
J45M Poly Ear cushion for Poly EncorePro HW530, HW540 In Stock £2.51
J45M Poly - Audio cable - M22 to Quick Disconnect - for Poly EncorePro In Stock £10.80
Brand: Poly
