The EncorePro 500 Series smarter headsets let your employees take calls from home or office, regardless of how they connect to a PC. They're the first call center digital headsets to connect you to everything Teams has to offer, even while you're on a call. Hybrid working has never been easier.
Built-in Hold and Call Answer buttons
Make every call easier with clear, built-in hold and call answer buttons. -
Recessed buttons
Eliminate button-pushing mistakes with recessed buttons that don't get accidently activated. -
Single button for joint audio/video hold
Enjoy worry-free privacy and peace of mind with a single button for joint audio and video hold.
- Poly EncorePro HW520D - headset - Quick Disconnect
- Product Type
- Headset - wired - Quick Disconnect
- Recommended Use
- Computer
- Black
- Headphones Form Factor
- On-ear binaural
- Connectivity Technology
- Wired
- Audio Specifications
- Frequency Response 20 - 10000 Hz
- Signal-To-Noise Ratio
- 50 dB
- Microphone
- Boom
- Microphone Operation Mode
- Omni-directional
- Microphone Noise Cancelling
- Software Certification
- Certified for Skype for Business
- 2-year warranty
- Product Type
- Series
- EncorePro 500 series
- 11.1 cm
- 14.9 cm
- 6.7 cm
- 74 g
- Black
- Earpad Material
- Artificial leather
- Recommended Use
- Computer
- 290° rotatable microphone, boom mic length 135mm
Audio Output
- On-ear binaural
- Wired
- 20 - 10000 Hz
- 50 dB
- Diaphragm
- 5.6 mm
Microphone
- Boom
- Omni-directional
- Sensitivity
- 40 dB
- Sensitivity Margin
- +/- 3dB
- 20 - 16000 Hz
- Noise Cancelling
- Connector Type
- Headset (Quick Disconnect)
Cable
- Cable Length
- 78.5 cm
- Supported Host Device OS
- Windows, macOS
- Limited warranty - 2 years
- Shipping Width
- 13.78 cm
- Shipping Depth
- 17.8 cm
- Shipping Height
- 5.46 cm
- Shipping Weight
- 180 g
Poly Headset Splitter - Y-type training cable for Poly Blackwire 5200 | In Stock | £12.79 |
Poly EncorePro HW510/520 Foam Ear Cushions | In Stock | £1.98 |
Poly DA85 Headset Cable - USB-C to Quick Disconnect | In Stock | £53.34 |
Poly Headset Cable - RJ-45 to Quick Disconnect | In Stock | £9.54 |
Poly Ear cushion for Poly EncorePro HW530, HW540 | In Stock | £2.44 |
Poly Quick Disconnect to Quick Disconnect Extension Cable - 3m | In Stock | £8.85 |
Poly U10P-S - Headset cable - for Poly EncorePro | In Stock | £9.54 |
Poly - Ear cushion for headset - leatherette - black (pack of 2) | In Stock | £5.97 |
Poly - Audio cable - M22 to Quick Disconnect - for Poly EncorePro | In Stock | £10.48 |
