Poly EncorePro HW510 Mono Headset (VT)
Quicklinx: HM5ZWS00 Mfr#: 783Q4AA#ABB
Recommended Use: Portable electronics
Connectivity: Wired
Earcover : Monaural
Hurry, only 3 left in stock!
£70.81 ex VAT
£84.97 inc VAT
The Plantronics EncorePro 510 Monaural is a corded headset for desk phones with noise-cancelling microphone - ideal for those who need to be available all day, everyday.
Perfect for clearer communication
The new design of the Plantronics EncorePro range features smooth tactile feedback, allowing you to adjust your microphone to the perfect position for clearer conversation. The next generation noise-cancelling microphone features enhanced echo and background noise cancellation for a better caller experience. Wideband audio offers rich, clear voice quality, whilst acoustic protection with Plantronics' SoundGuard technology helps to protect the user from noise spikes and listening fatigue.
Unibody headset
To ensure perfect microphone positioning, the EncorePro 510 users can feel and hear the ratchet clicks, when moving their microphone boom, alerting them to the proper positioning for optimum voice detection. The 'unibody' boom itself is part of the headset as a whole, meaning that there is no part to break off - strengthening a key area that is frequently damaged with intensive headset use.
Fast connectivity
The Quick Disconnect feature gives you the opportunity to conveniently and quickly walk away from your desk, as well as making it compatible with all USB and deskphone audio processors in addition to direct connect cables.
Hearing Aid Compatible
This headset is hearing aid compatible (assuming telecoil feature is available in the hearing aid). This headset is also an approved HAC product by Poly (Plantronics).
  • Exceptional audio clarity
    Experience crystal-clear conversations with a frequency response range of 20 - 16000 Hz and a signal-to-noise ratio of 50 dB, ensuring every word is heard with impeccable clarity.
  • Advanced noise cancellation
    Equipped with an omnidirectional, noise-canceling microphone, this headset minimizes background noise, allowing for uninterrupted communication in noisy environments.
  • Comfortable design
    Featuring on-the-go headphones with PU leather earpads and a 290° rotatable microphone, this headset combines comfort with flexibility for all-day wear.
  • Reliable connectivity
    With a wired connection through a 3.5 mm jack and a 78.5 cm cable, this headset offers dependable and consistent audio quality for all your calls and multimedia needs.
Poly EncorePro 510V - headset - 3.5 mm jack
Headset - wired - 3.5 mm jack
English / Europe
Headphones Form Factor
On-ear
Wired
Signal-To-Noise Ratio
50 dB
Microphone
Boom
Microphone Operation Mode
Omni-directional
Microphone Noise Cancelling
Software Certification
Certified for Skype for Business, UC certified
Series
EncorePro 500 series
11.1 cm
14.9 cm
6.7 cm
52 g
Earpad Material
PU leather
290° rotatable microphone, boom mic length 135mm
English / Europe
Audio Output
On-ear
Wired
50 dB
Diaphragm
5.6 mm
Microphone
Boom
Omni-directional
Sensitivity
40 dB
Sensitivity Margin
+/- 3dB
Frequency Response
20 - 16000 Hz
Noise Cancelling
Connector Type
Headset (mini-phone 3.5mm)
Cable
Cable Length
78.5 cm
Supported Host Device OS
Windows, macOS
Shipping Width
13.78 cm
Shipping Depth
17.8 cm
Shipping Height
5.46 cm
Shipping Weight
140 g
HM5Z Poly Headset Splitter - Y-type training cable for Poly Blackwire 5200 In Stock £12.98
HM5Z Poly Headset Splitter - Y-type training cable for Poly EncorePro In Stock £24.19
HM5Z Poly DA75 Sound Card In Stock £26.82
HM5Z Poly DA85-M Sound Card In Stock £43.86
HM5Z Poly Headset Splitter - Y-Type Training Cable In Stock £22.24
HM5Z Poly Headset Cable - M22 to Quick Disconnect for Poly M22 In Stock £10.53
HM5Z Poly EncorePro HW510/520 Foam Ear Cushions In Stock £1.98
HM5Z Poly DA85 Headset Cable - USB-C to Quick Disconnect In Stock £43.86
HM5Z Poly HIS Adapter Cable In Stock £15.68
HM5Z Poly Headset Cable - RJ-45 to Quick Disconnect In Stock £9.20
HM5Z Poly U10P Headset Cable In Stock £12.42
HM5Z Poly Quick Disconnect to Quick Disconnect Extension Cable - 3m In Stock £8.64
HM5Z Poly U10P-S - Headset cable - for Poly EncorePro In Stock £9.31
HM5Z Poly - Ear cushion for headset - leatherette - black (pack of 2) In Stock £5.83
HM5Z Poly - Audio cable - M22 to Quick Disconnect - for Poly EncorePro In Stock £10.25
Connectivity: Wired
Earcover : Monaural
Brand: Poly
