Poly EncorePro HW510 Mono Headset (VT)
Quicklinx: HM5ZWS00 Mfr#: 783Q4AA#ABB
Recommended Use: Portable electronics
Connectivity: Wired
Earcover : Monaural
43 In Stock
£72.63 ex VAT
£87.15 inc VAT
The Plantronics EncorePro 510 Monaural is a corded headset for desk phones with noise-cancelling microphone - ideal for those who need to be available all day, everyday.
Perfect for clearer communication
The new design of the Plantronics EncorePro range features smooth tactile feedback, allowing you to adjust your microphone to the perfect position for clearer conversation. The next generation noise-cancelling microphone features enhanced echo and background noise cancellation for a better caller experience. Wideband audio offers rich, clear voice quality, whilst acoustic protection with Plantronics' SoundGuard technology helps to protect the user from noise spikes and listening fatigue.
Unibody headset
To ensure perfect microphone positioning, the EncorePro 510 users can feel and hear the ratchet clicks, when moving their microphone boom, alerting them to the proper positioning for optimum voice detection. The 'unibody' boom itself is part of the headset as a whole, meaning that there is no part to break off - strengthening a key area that is frequently damaged with intensive headset use.
Fast connectivity
The Quick Disconnect feature gives you the opportunity to conveniently and quickly walk away from your desk, as well as making it compatible with all USB and deskphone audio processors in addition to direct connect cables.
Hearing Aid Compatible
This headset is hearing aid compatible (assuming telecoil feature is available in the hearing aid). This headset is also an approved HAC product by Poly (Plantronics).
  • Voice tube design
    Our voice tube microphone design ensures clear voice delivery without distraction. The detachable voice tube is both clear and easy to clean or replace.
  • Expanded compatibility
    Walk away from your desk with a click thanks to Poly Quick Disconnect (QD) technology that works with any Poly QD adapter.
  • Optimized for communications platforms
    An IT manager's dream, this headset was created for communication and is optimized and certified to work with top virtual meeting providers.
  • Acoustic hearing protection
    SoundGuard is the acoustic limiting technology that is present in all communications headsets from Poly that protects against Acoustic Shock by limiting sounds to below 118dBA.
  • Recessed buttons
    Eliminate button-pushing mistakes with recessed buttons that don't get accidently activated.
  • Single button for joint audio/video hold
    Enjoy worry-free privacy and peace of mind with a single button for joint audio and video hold.
Poly EncorePro 510V - headset
Headset - wired - 3.5 mm jack
English / Europe
Headphones Form Factor
On-ear
Wired
Signal-To-Noise Ratio
50 dB
Microphone
Boom
Microphone Operation Mode
Omni-directional
Microphone Noise Cancelling
Software Certification
Certified for Skype for Business, UC certified
Series
EncorePro 500 series
11.1 cm
14.9 cm
6.7 cm
52 g
Earpad Material
PU leather
Boom mic length 135mm, 290° rotatable microphone
English / Europe
Audio Output
On-ear
Wired
50 dB
Diaphragm
5.6 mm
Microphone
Boom
Omni-directional
Sensitivity
40 dB
Sensitivity Margin
+/- 3dB
Frequency Response
20 - 16000 Hz
Noise Cancelling
Connector Type
Headset (mini-phone 3.5mm)
Cable
Cable Length
78.5 cm
Supported Host Device OS
macOS, Windows
Shipping Width
13.78 cm
Shipping Depth
17.8 cm
Shipping Height
5.46 cm
Shipping Weight
140 g
HM5Z Poly Headset Splitter - Y-type training cable for Poly Blackwire 5200 In Stock £13.42
HM5Z Poly Headset Splitter - Y-type training cable for Poly EncorePro In Stock £25.89
HM5Z Poly Audio Cable - M22 to Quick Disconnect for Poly EncorePro In Stock £10.99
HM5Z Poly DA75 Sound Card In Stock £32.13
HM5Z Poly DA85-M Sound Card In Stock £53.78
HM5Z Poly EncorePro HW510/520 Foam Ear Cushions In Stock £1.98
HM5Z Poly DA85 Headset Cable - USB-C to Quick Disconnect In Stock £52.54
HM5Z Poly HIS Adapter Cable In Stock £24.71
Connectivity: Wired
Earcover : Monaural
Brand: Poly
