The Plantronics EncorePro 510 Monaural is a corded headset for desk phones with noise-cancelling microphone - ideal for those who need to be available all day, everyday.
Perfect for clearer communication
The new design of the Plantronics EncorePro range features smooth tactile feedback, allowing you to adjust your microphone to the perfect position for clearer conversation. The next generation noise-cancelling microphone features enhanced echo and background noise cancellation for a better caller experience. Wideband audio offers rich, clear voice quality, whilst acoustic protection with Plantronics' SoundGuard technology helps to protect the user from noise spikes and listening fatigue.
Unibody headset
To ensure perfect microphone positioning, the EncorePro 510 users can feel and hear the ratchet clicks, when moving their microphone boom, alerting them to the proper positioning for optimum voice detection. The 'unibody' boom itself is part of the headset as a whole, meaning that there is no part to break off - strengthening a key area that is frequently damaged with intensive headset use.
Fast connectivity
The Quick Disconnect feature gives you the opportunity to conveniently and quickly walk away from your desk, as well as making it compatible with all USB and deskphone audio processors in addition to direct connect cables.
Hearing Aid Compatible
This headset is hearing aid compatible (assuming telecoil feature is available in the hearing aid). This headset is also an approved HAC product by Poly (Plantronics).
Exceptional audio clarity
Experience crystal-clear conversations with a frequency response range of 20 - 16000 Hz and a signal-to-noise ratio of 50 dB, ensuring every word is heard with impeccable clarity. -
Advanced noise cancellation
Equipped with an omnidirectional, noise-canceling microphone, this headset minimizes background noise, allowing for uninterrupted communication in noisy environments. -
Comfortable design
Featuring on-the-go headphones with PU leather earpads and a 290° rotatable microphone, this headset combines comfort with flexibility for all-day wear. -
Reliable connectivity
With a wired connection through a 3.5 mm jack and a 78.5 cm cable, this headset offers dependable and consistent audio quality for all your calls and multimedia needs.
- Poly EncorePro 510V - headset - 3.5 mm jack
- Product Type
- Headset - wired - 3.5 mm jack
- Localisation
- English / Europe
- Black
- Headphones Form Factor
- On-ear
- Connectivity Technology
- Wired
- Signal-To-Noise Ratio
- 50 dB
- Microphone
- Boom
- Microphone Operation Mode
- Omni-directional
- Microphone Noise Cancelling
- Software Certification
- Certified for Skype for Business, UC certified
- 2-year warranty
- Product Type
- Series
- EncorePro 500 series
- 11.1 cm
- 14.9 cm
- 6.7 cm
- 52 g
- Black
- Earpad Material
- PU leather
- 290° rotatable microphone, boom mic length 135mm
- Localisation
- English / Europe
Audio Output
- On-ear
- Wired
- 50 dB
- Diaphragm
- 5.6 mm
Microphone
- Boom
- Omni-directional
- Sensitivity
- 40 dB
- Sensitivity Margin
- +/- 3dB
- Frequency Response
- 20 - 16000 Hz
- Noise Cancelling
- Connector Type
- Headset (mini-phone 3.5mm)
Cable
- Cable Length
- 78.5 cm
- Supported Host Device OS
- Windows, macOS
- Limited warranty - 2 years
- Shipping Width
- 13.78 cm
- Shipping Depth
- 17.8 cm
- Shipping Height
- 5.46 cm
- Shipping Weight
- 140 g
Poly DA85-M Sound Card | In Stock | £44.59 |
Poly Headset Cable - M22 to Quick Disconnect for Poly M22 | In Stock | £10.68 |
Poly EncorePro HW510/520 Foam Ear Cushions | In Stock | £2.04 |
Poly DA85 Headset Cable - USB-C to Quick Disconnect | In Stock | £44.59 |
Poly HIS Adapter Cable | In Stock | £25.46 |
Poly Ear cushion for Poly EncorePro HW530, HW540 | In Stock | £2.51 |
Poly Quick Disconnect to Quick Disconnect Extension Cable - 3m | In Stock | £9.00 |
Poly U10P-S - Headset cable - for Poly EncorePro | In Stock | £9.73 |
Poly - Audio cable - M22 to Quick Disconnect - for Poly EncorePro | In Stock | £10.80 |
