Unleash your call center productivity with the EncorePro 500 Series headsets. Connecting your headset to your PC, from home or the office, is easy with multiple options. And with the lightweight and comfy design, your agents will stay engaged.
Noise-canceling microphone
Next-generation flexible microphone, with positioning guides, reduces background noise and interference, ensuring fewer missed words and a better caller experience. -
Expanded compatibility
Walk away from your desk with a click thanks to Poly Quick Disconnect (QD) technology that works with any Poly QD adapter. -
Optimized for communications platforms
An IT manager's dream, this headset was created for communication and is optimized and certified to work with top virtual meeting providers. -
Acoustic hearing protection
SoundGuard is the acoustic limiting technology that is present in all communications headsets from Poly that protects against Acoustic Shock by limiting sounds to below 118dBA. -
Recessed buttons
Eliminate button-pushing mistakes with recessed buttons that don't get accidently activated. -
Single button for joint audio/video hold
Enjoy worry-free privacy and peace of mind with a single button for joint audio and video hold.
- Poly EncorePro 530 - headset - Quick Disconnect
- Product Type
- Headset - wired - Quick Disconnect
- Recommended Use
- Computer, phone, portable electronics
- Localisation
- English / Europe
- Black
- Headphones Form Factor
- In-ear monaural
- Connectivity Technology
- Wired
- Signal-To-Noise Ratio
- 50 dB
- Microphone
- Boom
- Microphone Operation Mode
- Omni-directional
- Microphone Noise Cancelling
- Software Certification
- UC certified, Certified for Skype for Business
- 2-year warranty
- Product Type
- Series
- EncorePro 500 series
- 11.1 cm
- 14.9 cm
- 6.7 cm
- 22 g
- Black
- Earpad Material
- Artificial leather
- Recommended Use
- 290° rotatable microphone, boom mic length 135mm
- Localisation
- English / Europe
Audio Output
- In-ear monaural
- Wired
- 50 dB
- Diaphragm
- 7.2 mm
Microphone
- Boom
- Omni-directional
- Sensitivity
- 38 dB
- Sensitivity Margin
- +/- 3dB
- Frequency Response
- 20 - 16000 Hz
- Noise Cancelling
- Connector Type
- Headset (Quick Disconnect)
Cable
- Cable Length
- 1.35 m
- Supported Host Device OS
- Windows, macOS
- Limited warranty - 2 years
- Shipping Width
- 19 cm
- Shipping Depth
- 17.5 cm
- Shipping Height
- 5.5 cm
- Shipping Weight
- 150 g
Poly Headset Splitter - Y-type training cable for Poly Blackwire 5200 | In Stock | £13.58 |
Poly DA85-M Sound Card | In Stock | £44.59 |
Poly Headset Cable - M22 to Quick Disconnect for Poly M22 | In Stock | £10.68 |
Poly EncorePro HW510/520 Foam Ear Cushions | In Stock | £2.05 |
Poly DA85 Headset Cable - USB-C to Quick Disconnect | In Stock | £44.79 |
Poly HIS Adapter Cable | In Stock | £24.11 |
Poly Ear cushion for Poly EncorePro HW530, HW540 | In Stock | £2.51 |
Poly Quick Disconnect to Quick Disconnect Extension Cable - 3m | In Stock | £9.00 |
Poly U10P-S - Headset cable - for Poly EncorePro | In Stock | £9.73 |
Poly - Ear cushion for headset - leatherette - black (pack of 2) | In Stock | £7.93 |
Poly - Audio cable - M22 to Quick Disconnect - for Poly EncorePro | In Stock | £10.80 |
