Poly EncorePro 530 - headset - Quick Disconnect
Quicklinx: HZ9KWS00 Mfr#: 783P3AA#ABB
Recommended Use: Phone, Phone, Computer, Portable electronics
Connectivity: Wired
£68.48 ex VAT
£82.17 inc VAT
Unleash your call center productivity with the EncorePro 500 Series headsets. Connecting your headset to your PC, from home or the office, is easy with multiple options. And with the lightweight and comfy design, your agents will stay engaged.
  • Noise-canceling microphone
    Next-generation flexible microphone, with positioning guides, reduces background noise and interference, ensuring fewer missed words and a better caller experience.
  • Expanded compatibility
    Walk away from your desk with a click thanks to Poly Quick Disconnect (QD) technology that works with any Poly QD adapter.
  • Optimized for communications platforms
    An IT manager's dream, this headset was created for communication and is optimized and certified to work with top virtual meeting providers.
  • Acoustic hearing protection
    SoundGuard is the acoustic limiting technology that is present in all communications headsets from Poly that protects against Acoustic Shock by limiting sounds to below 118dBA.
  • Recessed buttons
    Eliminate button-pushing mistakes with recessed buttons that don't get accidently activated.
  • Single button for joint audio/video hold
    Enjoy worry-free privacy and peace of mind with a single button for joint audio and video hold.
Headset - wired - Quick Disconnect
Recommended Use
Computer, phone, portable electronics
English / Europe
Headphones Form Factor
In-ear monaural
Wired
Signal-To-Noise Ratio
50 dB
Microphone
Boom
Microphone Operation Mode
Omni-directional
Microphone Noise Cancelling
Software Certification
UC certified, Certified for Skype for Business
Series
EncorePro 500 series
11.1 cm
14.9 cm
6.7 cm
22 g
Earpad Material
Artificial leather
Recommended Use
290° rotatable microphone, boom mic length 135mm
English / Europe
Audio Output
In-ear monaural
Wired
50 dB
Diaphragm
7.2 mm
Microphone
Boom
Omni-directional
Sensitivity
38 dB
Sensitivity Margin
+/- 3dB
Frequency Response
20 - 16000 Hz
Noise Cancelling
Connector Type
Headset (Quick Disconnect)
Cable
Cable Length
1.35 m
Supported Host Device OS
Windows, macOS
Shipping Width
19 cm
Shipping Depth
17.5 cm
Shipping Height
5.5 cm
Shipping Weight
150 g
HZ9K Poly Headset Splitter - Y-type training cable for Poly Blackwire 5200 In Stock £12.95
HZ9K Poly Headset Splitter - Y-type training cable for Poly EncorePro In Stock £24.69
HZ9K Poly DA85-M Sound Card In Stock £44.59
HZ9K Poly EncorePro HW510/520 Foam Ear Cushions In Stock £2.05
HZ9K Poly DA85 Headset Cable - USB-C to Quick Disconnect In Stock £43.25
HZ9K Poly HIS Adapter Cable In Stock £24.69
HZ9K Poly Ear cushion for Poly EncorePro HW530, HW540 In Stock £2.51
HZ9K Poly Quick Disconnect to Quick Disconnect Extension Cable - 3m In Stock £9.00
HZ9K Poly U10P-S - Headset cable - for Poly EncorePro In Stock £9.73
HZ9K Poly - Ear cushion for headset - leatherette - black (pack of 2) In Stock £7.93
HZ9K Poly - Audio cable - M22 to Quick Disconnect - for Poly EncorePro In Stock £10.80
Recommended Use: Computer
Recommended Use: Portable electronics
Connectivity: Wired
Brand: Poly
