Unleash your call center productivity with the EncorePro 500 Series headsets. Connecting your headset to your PC, from home or the office, is easy with multiple options. And with the lightweight and comfy design, your agents will stay engaged.
Noise canceling microphone
Next-generation flexible microphone, with positioning guides, reduces background noise and interference, ensuring fewer missed words and a better caller experience. -
Easy management via Poly Lens
Take control of your deployment from anywhere via remote management with Poly Lens cloud-based device management software. -
Connection flexibility
Easily answer calls from your PC, regardless of the type of USB port you have, thanks to the convenient built-in USB-A and USB Type-C ? connectors on the same cable. -
Certified for Microsoft Teams
Full Microsoft Teams certification takes your Microsoft Teams experience to the next level with a button for instant access to the app and more. -
Acoustic hearing protection
SoundGuard DIGITAL uses sophisticated algorithms to provide additional acoustic protection, above and beyond the impulse and long duration protection provided by SoundGuard while maintaining natural sounding speech.
- Poly EncorePro 525-M - headset - USB-A
- Product Type
- Headset - wired - USB-A
- Compatibility
- Windows, Mac
- Recommended Use
- Computer
- Black
- Headphones Form Factor
- On-ear
- Connectivity Technology
- Wired
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 20 - 20000 Hz
- Microphone
- Boom
- Microphone Operation Mode
- Omni-directional
- Microphone Noise Cancelling
- Controls
- Mute, volume, answer/end
- Software Certification
- Certified for Microsoft Teams
- Product Type
- Series
- EncorePro 500 series
- Compatibility
- Windows, Mac
- 11.1 cm
- 14.9 cm
- 6.7 cm
- 74 g
- Black
- Earpad Material
- Foam
- Recommended Use
- Computer
- Boom mic length 135mm
Audio Output
- On-ear
- Wired
- Sound Output Mode
- Stereo
- 20 - 20000 Hz
- Diaphragm
- 5.6 mm
- SoundGuard DIGITAL Technology
Microphone
- Boom
- Omni-directional
- Sensitivity
- 40 dB
- Sensitivity Margin
- +/- 3dB
- 35 - 21000 Hz
- Signal-To-Noise Ratio
- 53 dB
- Noise Cancelling
Remote Control
- Controls
- Connector Type
- USB (USB Type-A)
Cable
- Cable Length
- 2.085 m
- Supported Host Device OS
- Windows, macOS
- Shipping Width
- 19 cm
- Shipping Depth
- 17.5 cm
- Shipping Height
- 5.5 cm
- Shipping Weight
- 160 g
Poly Headset Splitter - Y-type training cable for Poly Blackwire 5200 | In Stock | £13.14 |
Poly DA75 Sound Card | In Stock | £33.08 |
Poly Headset Cable - M22 to Quick Disconnect for Poly M22 | In Stock | £10.74 |
Poly DA85 Headset Cable - USB-C to Quick Disconnect | In Stock | £43.34 |
Poly HIS Adapter Cable | In Stock | £25.71 |
Poly U10P-S - Headset cable - for Poly EncorePro | In Stock | £9.78 |
Poly - Audio cable - M22 to Quick Disconnect - for Poly EncorePro | In Stock | £10.80 |
Poly MDA524 QD - handset/computer/headset switch for headset, desk phone - QD, USB-A | In Stock | £98.81 |
