Poly EncorePro 520V - headset - on-ear - wired - 3.5 mm jack - black
Quicklinx: JDHZWS00 Mfr#: 783P9AA
Unleash your call center productivity with the EncorePro 500 Series headsets. Connecting your headset to your PC, from home or the office, is easy with multiple options. And with the lightweight and comfy design, your agents will stay engaged.
HP Poly EncorePro 520V - headset - Quick Disconnect
Headset - wired - Quick Disconnect
Headphones Form Factor
On-ear
Wired
Signal-To-Noise Ratio
50 dB
Microphone
Boom
Microphone Operation Mode
Omni-directional
Microphone Noise Cancelling
Software Certification
Certified for Skype for Business, UC certified
Series
EncorePro 500 series
11.1 cm
14.9 cm
6.7 cm
74 g
Earpad Material
Artificial leather
290° rotatable microphone, boom mic length 135mm
Audio Output
On-ear
Wired
50 dB
Diaphragm
5.6 mm
Microphone
Boom
Omni-directional
Sensitivity
40 dB
Sensitivity Margin
+/- 3dB
Frequency Response
20 - 16000 Hz
Noise Cancelling
Connector Type
Headset (Quick Disconnect)
Cable
Cable Length
78.5 cm
Supported Host Device OS
Windows, macOS
Shipping Width
13.78 cm
Shipping Depth
17.8 cm
Shipping Height
5.46 cm
Shipping Weight
180 g
JDHZ Poly Headset Splitter - Y-type training cable for Poly Blackwire 5200 In Stock £13.14
JDHZ Poly DA85-M Sound Card In Stock £44.59
JDHZ Poly DA85 Headset Cable - USB-C to Quick Disconnect In Stock £43.62
JDHZ Poly HIS Adapter Cable In Stock £24.75
JDHZ Poly Ear cushion for Poly EncorePro HW530, HW540 In Stock £2.51
JDHZ Poly - Audio cable - M22 to Quick Disconnect - for Poly EncorePro In Stock £10.80
