Poly Edge E350 IP Phone
Quicklinx: HNK3WS00 Mfr#: 82M89AA
£123.20 ex VAT
£147.84 inc VAT
Easy to use and packed with features, the Poly Edge E300 Series pairs Poly noise reduction technology with cutting-edge design. Whether you're hot-desking at work or calling from your home office, these phones bring style to any desktop.
  • All the features you could ask for
    Get fast access to features via the 3.5" color display with a surround light status indicator and soft keys under the display. 8-line keys support up to 32 lines and contacts. A new pagination key brings additional lines/contacts into view.
  • Versatile connectivity
    Enjoy better connectivity with two high-speed GigE PoE Ethernet ports for the LAN connection to your IP phone with a passthrough connection to your PC. And a Poly headset for your workstyle: Bluetooth , USB, RJ9, or Electronic Hook Switch.
  • Perfectly paired
    Integrated Bluetooth 5.0 gives you freedom to move about the office with your Poly Bluetooth headset and answer your mobile phone calls from your desk phone. Fast pairing on selected Poly headsets makes connecting your headset easy.
  • Works wherever you do
    The Poly Edge E350 is Wi-Fi-ready for hassle-free performance at home or office. Work anywhere with 802.11AC Wi-Fi included. With simple out-of-the-box Wi-Fi configuration, this phone gives you peak performance anywhere you've got a signal.
  • Accessibility is key
    Enhance the user experience with phones that sound great and are more efficient. Features like improved accessibility with text-to-speech, screen color adjustments for color blindness, and bigger font settings provide more ways to connect.
HP Poly Edge E350 - VoIP phone with caller ID/call waiting - 3-way call capability
VoIP Protocols
SIP, SDP
Voice Codecs
G.711a-law, G.711µ-law, G.729ab, G.722, G.722.1, iLBC, Opus
Speakerphone
Call Services
Call Waiting, Call Transfer, Call Hold, Voice Mail, Call park/pickup, Caller ID
Display
LCD display - colour - Yes
Display Features
4:3 aspect ratio
Network Ports Qty
2 x Ethernet 10Base-T/100Base-TX/1000Base-T
Compatible Software
Zoom, RingCentral, Microsoft Teams, OpenSIP HSP/ITSP
Body Colour
Midnight blue, white
Environmental Standards
ENERGY STAR Qualified
1-year warranty
VoIP phone
Shipping Weight
960 g
Body Colour
Protection
Antimicrobial
Phone Features
Wireless Interface Provided
Bluetooth / NFC / Wi-Fi
Call Services
Caller ID Type
Caller ID/call waiting
Dialer Location
Base
Conference Call Capability
3-way
Speakerphone
Volume Control
Indicators
Line status indicator, busy lamp field (BLF), missed call indicator
Additional Functions
Redial, Do Not Disturb (DND), Call timer, pairing with mobile phone, bluetooth headset support
IP Telephony
VoIP
VoIP Protocols
SIP, SDP
Voice Codecs
Quality of Service
Diffserv per device (QoS), IEEE 802.1p, IEEE 802.1Q (VLAN), Layer 3 TOS
IP Address Assignment
DHCP
Security
SSL, IEEE 802.1X, TLS, EAPoL, WEP, WPA-Personal, WPA2-Enterprise, EAP-TLS, PEAP-MSCHAPv2
Power Over Ethernet (PoE) Support
Network Protocols
IETF SIP, SNTP, FTP, FTPS, TFTP, HTTP, HTTPS, Link Layer Discovery Protocol - Media Endpoint Discovery (LLDP-MED), VLAN-CDP, RTCP, RTP, TCP, UDP, DNS SRV
Network Ports Qty
Compatible Software
Voice Features
Poly HD Voice technology, Poly Acoustic Clarity technology, Poly Acoustic Fence technology, Poly NoiseBlockAI, voice activity detection (VAD), comfort noise generation (CNG), low-delay audio packet transmission, adaptive jitter buffer (AJB), packet loss concealment (PLC)
Network Features
Lightweight Directory Access Protocol (LDAP), Network Address Translation (NAT), Keep-Alive SIP signalling, Class 3 PoE, Poly LENS Cloud Management
Phone Memory
One-Touch Dial Button Qty
8
Display
Display Location
Base
Diagonal Size
3.5"
Display Resolution
320 x 240 pixels
Backlit
Display Languages
Multilingual
4:3 aspect ratio
USB Type-C / 24 pin USB-C , Headset jack / RJ-9
Hearing Aid Compatible
Placing / Mounting
Table-top, wall-mountable
Network cable , Handset cord
Stand
Internet of Things (IoT)
Communications Technology
Bluetooth 5.0, Wi-Fi
ENERGY STAR Certified
Power Consumption
13 W (PoE)
Shipping Width
22.3 cm
Shipping Depth
27.8 cm
Shipping Height
8.8 cm
Shipping Weight
960 g
Limited warranty - 1 year
Brand: Poly
