Easy to use and packed with features, the Poly Edge E300 Series pairs Poly noise reduction technology with cutting-edge design. Whether you're hot-desking at work or calling from your home office, these phones bring style to any desktop.
All the features you could ask for
Get fast access to features via the 3.5" color display with a surround light status indicator and soft keys under the display. 8-line keys support up to 32 lines and contacts. A new pagination key brings additional lines/contacts into view. -
Versatile connectivity
Enjoy better connectivity with two high-speed GigE PoE Ethernet ports for the LAN connection to your IP phone with a passthrough connection to your PC. And a Poly headset for your workstyle: Bluetooth , USB, RJ9, or Electronic Hook Switch. -
Perfectly paired
Integrated Bluetooth 5.0 gives you freedom to move about the office with your Poly Bluetooth headset and answer your mobile phone calls from your desk phone. Fast pairing on selected Poly headsets makes connecting your headset easy. -
Works wherever you do
The Poly Edge E350 is Wi-Fi-ready for hassle-free performance at home or office. Work anywhere with 802.11AC Wi-Fi included. With simple out-of-the-box Wi-Fi configuration, this phone gives you peak performance anywhere you've got a signal. -
Accessibility is key
Enhance the user experience with phones that sound great and are more efficient. Features like improved accessibility with text-to-speech, screen color adjustments for color blindness, and bigger font settings provide more ways to connect.
 - Poly Edge E350 - VoIP phone with caller ID/call waiting - 3-way call capability
- Product Type
- VoIP Protocols
 - SIP, SDP
- Voice Codecs
 - G.711a-law, G.711µ-law, G.729ab, G.722, G.722.1, iLBC, Opus
- Speakerphone
- Call Services
 - Call Waiting, Call Transfer, Call Hold, Voice Mail, Call park/pickup, Caller ID
- Display
 - LCD display - colour - Yes
- Display Features
 - 4:3 aspect ratio
- Network Ports Qty
 - 2 x Ethernet 10Base-T/100Base-TX/1000Base-T
- Compatible Software
 - Zoom, RingCentral, Microsoft Teams, OpenSIP HSP/ITSP
- Body Colour
 - Midnight blue, white
- Environmental Standards
 - ENERGY STAR Qualified
 - 1-year warranty
- Product Type
 - VoIP phone
- Shipping Weight
 - 960 g
- Body Colour
- Protection
 - Antimicrobial
Phone Features
- Wireless Interface Provided
 - Bluetooth / NFC / Wi-Fi
- Call Services
- Caller ID Type
 - Caller ID/call waiting
- Dialer Location
 - Base
- Conference Call Capability
 - 3-way
- Speakerphone
- Volume Control
- Indicators
 - Line status indicator, busy lamp field (BLF), missed call indicator
- Additional Functions
 - Redial, Do Not Disturb (DND), Call timer, pairing with mobile phone, bluetooth headset support
IP Telephony
- VoIP
- VoIP Protocols
 - SIP, SDP
- Voice Codecs
- Quality of Service
 - Diffserv per device (QoS), IEEE 802.1p, IEEE 802.1Q (VLAN), Layer 3 TOS
- IP Address Assignment
 - DHCP
- Security
 - SSL, IEEE 802.1X, TLS, EAPoL, WEP, WPA-Personal, WPA2-Enterprise, EAP-TLS, PEAP-MSCHAPv2
- Power Over Ethernet (PoE) Support
- Network Protocols
 - IETF SIP, SNTP, FTP, FTPS, TFTP, HTTP, HTTPS, Link Layer Discovery Protocol - Media Endpoint Discovery (LLDP-MED), VLAN-CDP, RTCP, RTP, TCP, UDP, DNS SRV
- Network Ports Qty
- Voice Features
 - Poly HD Voice technology, Poly Acoustic Clarity technology, Poly Acoustic Fence technology, Poly NoiseBlockAI, voice activity detection (VAD), comfort noise generation (CNG), low-delay audio packet transmission, adaptive jitter buffer (AJB), packet loss concealment (PLC)
- Network Features
 - Lightweight Directory Access Protocol (LDAP), Network Address Translation (NAT), Keep-Alive SIP signalling, Class 3 PoE, Poly LENS Cloud Management
Phone Memory
- One-Touch Dial Button Qty
 - 8
Display
- Display Location
 - Base
- Diagonal Size
 - 3.5"
- Display Resolution
 - 320 x 240 pixels
- Backlit
- Display Languages
 - Multilingual
 - 4:3 aspect ratio
- Connections
 - USB Type-C / 24 pin USB-C , Headset jack / RJ-9
- Hearing Aid Compatible
- Placing / Mounting
 - Table-top, wall-mountable
- Cables Included
 - Network cable , Handset cord
- Included Accessories
 - Stand
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Communications Technology
 - Bluetooth 5.0, Wi-Fi
- ENERGY STAR Certified
- Power Consumption
 - 13 W (PoE)
- Shipping Width
 - 22.3 cm
- Shipping Depth
 - 27.8 cm
- Shipping Height
 - 8.8 cm
- Shipping Weight
 - 960 g
 - Limited warranty - 1 year
