Easy to use and packed with features, the Poly Edge E220 IP desk phone keeps you sounding professional and productive. Bring style to any desktop or reception area with cutting-edge design and stay on track with Poly noise reduction technology.
                All the features you could ask forGet fast access to features via the main 2.8" color display with a light status indicator and soft keys under the display. 4-line keys support up to 16 lines and contacts. A new pagination key brings additional lines/contacts into view.
                Versatile connectivityEnjoy better connectivity with two high-speed GigE PoE Ethernet ports for the LAN connection to your IP phone with a passthrough connection to your PC. And a Poly headset for your workstyle: Bluetooth , USB, RJ9, or Electronic Hook Switch.
                Perfectly pairedIntegrated Bluetooth 5.0 gives you freedom to move about the office with your Poly Bluetooth headset and answer your mobile phone calls from your desk phone. Fast pairing on selected Poly headsets makes connecting your headset easy.
                Accessibility is keyEnhance the user experience with phones that sound great and are more efficient. Features like improved accessibility with text-to-speech, screen color adjustments for color blindness, and bigger font settings provide more ways to connect.
                Noise blocking technologyEliminate distracting background noise with Poly Acoustic Fence and NoiseBlockAI technologies.
                Style meets functionalityLet the phone compliment your office layout with a 2-position stand and wall mount hardware included.
- Poly Edge E220 - VoIP phone with caller ID/call waiting - 3-way call capability
- Product Type
- Main Features
- Integrated Ethernet switch, multiple VoIP protocol support
- VoIP Protocols
- SIP, SDP
- Voice Codecs
- G.711a-law, G.711µ-law, G.729ab, G.722, G.722.1, iLBC, Opus
- Lines Supported
- 16 lines
- Multiline Operation Capability
- Multi-line operation
- Speakerphone
- Call Services
- Call Waiting, Call Transfer, Call Hold, Voice Mail, Call park/pickup, Caller ID
- Display
- LCD display - colour - Yes
- Display Features
- 4:3 aspect ratio
- Network Ports Qty
- 2 x Ethernet 10Base-T/100Base-TX/1000Base-T
- Compatible Software
- Zoom, RingCentral, Microsoft Teams, OpenSIP HSP/ITSP
- Body Colour
- Midnight blue, white
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Product Type
- VoIP phone
- Shipping Weight
- 880 g
- Body Colour
- Protection
- Microban antimicrobial protection
Phone Features
- Wireless Interface Provided
- Bluetooth / NFC
- Call Services
- Caller ID Type
- Caller ID/call waiting
- Dialer Location
- Base
- Conference Call Capability
- 3-way
- Speakerphone
- Programmable Buttons Qty
- 4
- Volume Control
- Indicators
- Line status indicator, busy lamp field (BLF), missed call indicator
- Additional Functions
- Redial, Do Not Disturb (DND), Call timer, bluetooth headset support
IP Telephony
- Main Features
- VoIP
- VoIP Protocols
- SIP, SDP
- Voice Codecs
- Lines Supported
- 16 lines
- Quality of Service
- Diffserv per device (QoS), IEEE 802.1p, IEEE 802.1Q (VLAN), Layer 3 TOS
- IP Address Assignment
- DHCP
- Security
- IEEE 802.1X, TLS
- Power Over Ethernet (PoE) Support
- Network Protocols
- IETF SIP, SNTP, FTP, FTPS, TFTP, HTTP, HTTPS, Link Layer Discovery Protocol - Media Endpoint Discovery (LLDP-MED), VLAN-CDP, RTCP, RTP, TCP, UDP, DNS SRV
- Network Ports Qty
- Voice Features
- Poly HD Voice technology, Poly Acoustic Clarity technology, acoustic echo cancellation (AEC), background noise suppression, Poly Acoustic Fence technology, Poly NoiseBlockAI, voice activity detection (VAD), comfort noise generation (CNG), low-delay audio packet transmission, adaptive jitter buffer (AJB), packet loss concealment (PLC), dual tone multi-frequency (DTMF)
- Network Features
- Lightweight Directory Access Protocol (LDAP), Network Address Translation (NAT), Keep-Alive SIP signalling, Class 3 PoE, Poly LENS Cloud Management
Phone Memory
- One-Touch Dial Button Qty
- 4
Display
- Display Location
- Base
- Diagonal Size
- 2.8"
- Display Resolution
- 320 x 240 pixels
- Backlit
- Display Languages
- Multilingual
- 4:3 aspect ratio
- Connections
- USB Type-C / 24 pin USB-C , Headset jack / RJ-9 , EHS port
- Hearing Aid Compatible
- Placing / Mounting
- Table-top, wall-mountable
- Cables Included
- Network cable , Handset cord
- Included Accessories
- Wall mount, stand, power adapter
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Communications Technology
- Bluetooth 5.0
- ENERGY STAR Certified
- Power Consumption
- 13 W (PoE), 15 W (PSU)
- Shipping Width
- 22.3 cm
- Shipping Depth
- 25.5 cm
- Shipping Height
- 8.3 cm
- Shipping Weight
- 880 g
- Limited warranty - 1 year
