- Covers your entire ear to help seal in sound and eliminate ambient background noise from interfering with conversations
- Fits all Plantronics SupraPlus corded series headsets (H251N, H261N, etc.)
- Cushy soft leatherette material
- 3-inch wide by 4-inch tall
- Designed for high noise environments
Enhanced comfort
Designed specifically for headsets, this ear cushion kit offers an improved level of comfort for extended use. The soft materials used ensure a snug fit without causing discomfort, making it ideal for long conference calls or music sessions. -
Easy to install
The ear cushion kit is user-friendly and can be easily attached to your headset without the need for any tools. This convenience allows for quick replacement, ensuring your headset remains in good condition.
