- Covers your entire ear to help seal in sound and eliminate ambient background noise from interfering with conversations
- Fits all Plantronics SupraPlus corded series headsets (H251N, H261N, etc.)
- Cushy soft leatherette material
- 3-inch wide by 4-inch tall
- Designed for high noise environments
Enhanced comfort
Designed specifically for headsets, this ear cushion kit offers an improved level of comfort for extended use. The soft materials used ensure a snug fit without causing discomfort, making it ideal for long conference calls or music sessions. -
Easy to install
The ear cushion kit is user-friendly and can be easily attached to your headset without the need for any tools. This convenience allows for quick replacement, ensuring your headset remains in good condition.
Poly Ear Cushion Kit for Supra Plus
