Poly DA85 Headset Cable - USB-C to Quick Disconnect
Quicklinx: HM3MWS00 Mfr#: 786C7AA
£53.34 ex VAT
£64.00 inc VAT
Poly DA Series digital adapters keep call center employees sounding crystal-clear from home or in the office. With easy USB-A or USB Type-C ? connections, they adjust audio to each specific Poly headset, offering quality calls .
  • Inline controls
    With just one simple click, you can instantly mute all audio and visual transmissions - whether it's a phone call, a video conference, or a virtual meeting.
  • Connection flexibility
    Answer soft-phone calls from any PC, no matter what kind of USB port you have. Built-in USB-A and USB Type-C ? connectors on the same cable.
  • Smart headset recognition
    Get incredible call quality on any Poly headset via intelligent headset recognition that adjusts audio performance to the specific headset.
  • Quick disconnect
    Walk away from your desk with a click: Poly Quick Disconnect technology works with any Poly QD-equipped headset.
  • Acoustic hearing protection
    SoundGuard DIGITAL featuring advanced acoustic limiting, including daily noise exposure, G616, and anti-startle functionality.
  • Communications platforms
    An IT manager's dream, the Poly DA Series digital adapters were created for communication and are optimized and certified to work with top virtual meeting providers.
Poly DA85 - headset cable - 1.3 m
Cable
Headset cable
Length
1.3 m
Connectors
USB - male , 24 pin USB-C - male
Connectors (Second End)
Quick Disconnect
DAC Details
150 - 6800 Hz
In-line call control
OMEN 40L by HP GT21-1026nd; Poly DA70, DA75, DA80, DA85-M
Cable Type
Headset cable
Length
1.3 m
Adapters & Converters
Frequency Response
150 - 6800 Hz
Connectors
4 pin USB Type A - male , 24 pin USB-C - male
Quick Disconnect
2.5 cm
7.5 cm
1 cm
30 g
Shipping Width
9 cm
Shipping Depth
15 cm
Shipping Height
2.7 cm
Shipping Weight
71 g
OMEN 40L by HP GT21-1026nd , Poly DA70, DA75, DA80, DA85-M
Brand: Poly
