Poly DA Series digital adapters keep call center employees sounding crystal-clear from home or in the office. With easy USB-A or USB Type-C ? connections, they adjust audio to each specific Poly headset, offering quality calls .
Inline controls
With just one simple click, you can instantly mute all audio and visual transmissions - whether it's a phone call, a video conference, or a virtual meeting. -
Connection flexibility
Answer soft-phone calls from any PC, no matter what kind of USB port you have. Built-in USB-A and USB Type-C ? connectors on the same cable. -
Smart headset recognition
Get incredible call quality on any Poly headset via intelligent headset recognition that adjusts audio performance to the specific headset. -
Quick disconnect
Walk away from your desk with a click: Poly Quick Disconnect technology works with any Poly QD-equipped headset. -
Acoustic hearing protection
SoundGuard DIGITAL featuring advanced acoustic limiting, including daily noise exposure, G616, and anti-startle functionality. -
Communications platforms
An IT manager's dream, the Poly DA Series digital adapters were created for communication and are optimized and certified to work with top virtual meeting providers.
- HP Poly DA85 - headset cable - 1.3 m
- Cable
- Headset cable
- Cable Length
- 1.3 m
- Connectors
- USB - male ¦ USB-C - male
- Connectors (Second End)
- Quick Disconnect
- DAC Details
- 150 - 6800 Hz
- In-line call control
- Designed For
- OMEN 40L by HP GT21-1026nd; Poly DA70, DA75, DA80, DA85-M
- Cable Type
- Headset cable
- Cable Length
- 1.3 m
Adapters & Converters
- Frequency Response
- 150 - 6800 Hz
- Connectors
- 4 pin USB Type A - male ¦ 24 pin USB-C - male
- Quick Disconnect
- 2.5 cm
- 7.5 cm
- 1 cm
- 30 g
- Shipping Width
- 9 cm
- Shipping Depth
- 15 cm
- Shipping Height
- 2.7 cm
- Shipping Weight
- 71 g
- Designed For
- OMEN 40L by HP GT21-1026nd ¦ HP Poly DA70, DA75, DA80, DA85-M
