Poly DA Series digital adapters keep call center employees sounding crystal-clear from home or in the office. With easy USB-A or USB Type-C ? connections, they adjust audio to each specific Poly headset, offering quality calls .
                Inline controlsWith just one simple click, you can instantly mute all audio and visual transmissions - whether it's a phone call, a video conference, or a virtual meeting.
                Connection flexibilityAnswer soft-phone calls from any PC, no matter what kind of USB port you have. Built-in USB-A and USB Type-C ? connectors on the same cable.
                Smart headset recognitionGet incredible call quality on any Poly headset via intelligent headset recognition that adjusts audio performance to the specific headset.
                Quick disconnectWalk away from your desk with a click: Poly Quick Disconnect technology works with any Poly QD-equipped headset.
                Acoustic hearing protectionSoundGuard DIGITAL featuring advanced acoustic limiting, including daily noise exposure, G616, and anti-startle functionality.
                Communications platformsAn IT manager's dream, the Poly DA Series digital adapters were created for communication and are optimized and certified to work with top virtual meeting providers.
- Poly DA85 - headset cable - 1.3 m
- Cable
- Headset cable
- Length
- 1.3 m
- Connectors
- USB - male , 24 pin USB-C - male
- Connectors (Second End)
- Quick Disconnect
- DAC Details
- 150 - 6800 Hz
- In-line call control
- Designed For
- OMEN 40L by HP GT21-1026nd; Poly DA70, DA75, DA80, DA85-M
- Cable Type
- Headset cable
- Length
- 1.3 m
Adapters & Converters
- Frequency Response
- 150 - 6800 Hz
- Connectors
- 4 pin USB Type A - male , 24 pin USB-C - male
- Quick Disconnect
- 2.5 cm
- 7.5 cm
- 1 cm
- 30 g
- Shipping Width
- 9 cm
- Shipping Depth
- 15 cm
- Shipping Height
- 2.7 cm
- Shipping Weight
- 71 g
- Designed For
- OMEN 40L by HP GT21-1026nd , Poly DA70, DA75, DA80, DA85-M
