Poly DA85 Headset Cable - USB-C to Quick Disconnect
Quicklinx: HM3MWS00 Mfr#: 786C7AA
Hurry, only 2 left in stock!
£43.34 ex VAT
£52.00 inc VAT
Poly DA Series digital adapters keep call center employees sounding crystal-clear from home or in the office. With easy USB-A or USB Type-C ? connections, they adjust audio to each specific Poly headset, offering quality calls .
  • Inline controls
    With just one simple click, you can instantly mute all audio and visual transmissions - whether it's a phone call, a video conference, or a virtual meeting.
  • Connection flexibility
    Answer soft-phone calls from any PC, no matter what kind of USB port you have. Built-in USB-A and USB Type-C ? connectors on the same cable.
  • Smart headset recognition
    Get incredible call quality on any Poly headset via intelligent headset recognition that adjusts audio performance to the specific headset.
  • Quick disconnect
    Walk away from your desk with a click: Poly Quick Disconnect technology works with any Poly QD-equipped headset.
  • Acoustic hearing protection
    SoundGuard DIGITAL featuring advanced acoustic limiting, including daily noise exposure, G616, and anti-startle functionality.
  • Communications platforms
    An IT manager's dream, the Poly DA Series digital adapters were created for communication and are optimized and certified to work with top virtual meeting providers.
HP Poly DA85 - headset cable - 1.3 m
Cable
Headset cable
Cable Length
1.3 m
Connectors
USB - male , USB-C - male
Connectors (Second End)
Quick Disconnect
DAC Details
150 - 6800 Hz
In-line call control
OMEN 40L by HP GT21-1026nd; Poly DA70, DA75, DA80, DA85-M
Cable Type
Headset cable
Cable Length
1.3 m
Adapters & Converters
Frequency Response
150 - 6800 Hz
Connectors
4 pin USB Type A - male , 24 pin USB-C - male
Quick Disconnect
2.5 cm
7.5 cm
1 cm
30 g
Shipping Width
9 cm
Shipping Depth
15 cm
Shipping Height
2.7 cm
Shipping Weight
71 g
OMEN 40L by HP GT21-1026nd , HP Poly DA70, DA75, DA80, DA85-M
