Hybrid working? No problem. Poly DA75 digital adapters keep call center employees sounding clear at home or in the office with easy USB-A or USB-C connections. They even adjust audio to each specific headset, offering pro-grade call quality. This is a dedicated call center device, so there aren't any distractions for the employee - leading to shorter calls.
- Poly DA Series DA75 - sound card
- Sound card
- Enclosure Type
- External
- Interface Type
- USB-C / USB-A
- Hardware Controls And Indicators
- Answer/end, hold
- Sound card
- Form Factor
- External
- Interface Type
- USB-C / USB-A
Audio Output
- Answer/end, hold
- Echo cancellation, upgradeable firmware, acoustic hearing protection, works with Avaya, Genesys, & Cisco call centreplatforms, noise cancellation, automatic gain control
- USB - 4 pin USB Type A , 1 x headset - Quick Disconnect , USB - 24 pin USB-C
- Cables Included
- 1 x USB cable
- New releases update
