Sound better wherever you're working - at home, remote or in the office. With Calisto 5300, professional audio quality goes wireless.
Rich, clear audio anywhere
Hear and be heard, even when you're working from a remote location. The full-duplex 360° microphone makes your voice clear. With its amplified speaker and wide frequency response, it's even great for multimedia. -
Bluetooth connectivity
Built-in Bluetooth and USB connectivity lets you connect to all your devices. -
Superior audio quality
Enjoy full-duplex audio with 360° room coverage for easy, natural conversation. -
Dynamic mute alert
Dynamic mute alert senses and alerts you if you talk while muted. -
Compact and portable
A soft carrying case is included for easy storage and portability. -
Like a mobile conference room
You'll love how easy it is to pack up and set up - Calisto 5300 has an integrated cable management system and a convenient carrying case.
- Poly Calisto 5300 - speakerphone
- Product Type
- Speakerphone - Bluetooth - wireless
- Recommended Use
- Portable electronics, computer, conference - communication
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Audio Specifications
- Frequency Response 150 - 20000 Hz - Sensitivity 81.5 dB/Watt
- Impedance
- 4 Ohm
- Microphone Technology
- Condenser
- Microphone Operation Mode
- Omni-directional
- Controls
- Mute, volume control, on/off, answer/end
- Product Type
- 10.86 cm
- 10.86 cm
- 3.11 cm
- 214 g
- Recommended Use
- Voice alerts
Audio Output
- Wireless
- Bluetooth
- 150 - 20000 Hz
- Sensitivity
- 81.5 dB/Watt
- Impedance
- 4 Ohm
Microphone
- Form Factor
- Built-in
- Condenser
- Omni-directional
- Directivity Angle
- 360°
- 100 - 7500 Hz
Remote Control
- Controls
- Connector Type
- USB (4 PIN USB Type A)
- Included Accessories
- Carrying case, Bluetooth USB adapter
- Cable Details
- USB cable
- Battery
- Speaker phone battery lithium polymer
- Capacity
- 1000 mAh
- Run Time (Up To)
- 16 hour(s)
- Recharge Time
- 3.5 hour(s)
