Poly Blackwire C5220 Stereo USB-A Wired Headset
Quicklinx: FZJTWS00 Mfr#: 207576-201
Recommended Use: Computer
Connectivity: Wired
Earcover : Binaural
Hurry, only 1 left in stock!
£71.13 ex VAT
£85.35 inc VAT
Express delivery Delivered on Tuesday
The Blackwire 5200 Series fits your busy workday. Ergonomically designed, it's comfortable enough to wear all day, on your longest calls. The Blackwire 5200 Series - the power to connect and work easily is here.
Poly Blackwire C5220 USB-A - headset - USB, 3.5 mm jack
Headset - wired - USB, 3.5 mm jack
Recommended Use
Computer - communication
Headphones Form Factor
On-ear
Wired
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 20000 Hz
Microphone
Boom
Microphone Noise Cancelling
Controls
Mute, volume, answer/end
Series
5200 Series
20.9 cm
5.5 cm
18.6 cm
164.2 g
Headband Material
Cushioned metal
Earpad Material
Leatherette
Recommended Use
Voice alerts
Protection
Hearing protection
Audio Output
On-ear
Wired
Sound Output Mode
Stereo
Frequency Response
20 - 20000 Hz
In-Cord Volume Control
SoundGuard Technology
Microphone
Boom
Headset microphone
Frequency Response
100 - 8000 Hz
Noise Cancelling
Remote Control
Controls
Connector Type
USB (4 PIN USB Type A) , Headphones (mini-phone stereo 3.5 mm)
Carrying case
Cable Details
Headset cable
Connectivity: Wired
Earcover : Binaural
Brand: Poly
Stock Status: While stocks last
Stock Status: Clearance
