The Blackwire 5200 Series fits your busy workday. Ergonomically designed, it's comfortable enough to wear all day, on your longest calls. The Blackwire 5200 Series - the power to connect and work easily is here.
- Poly Blackwire C5220 USB-A - headset - USB, 3.5 mm jack
- Product Type
- Headset - wired - USB, 3.5 mm jack
- Recommended Use
- Computer - communication
- Headphones Form Factor
- On-ear
- Connectivity Technology
- Wired
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 20 - 20000 Hz
- Microphone
- Boom
- Microphone Noise Cancelling
- Controls
- Mute, volume, answer/end
- 2-year warranty
- Product Type
- Series
- 5200 Series
- 20.9 cm
- 5.5 cm
- 18.6 cm
- 164.2 g
- Headband Material
- Cushioned metal
- Earpad Material
- Leatherette
- Recommended Use
- Voice alerts
- Protection
- Hearing protection
Audio Output
- On-ear
- Wired
- Sound Output Mode
- Stereo
- 20 - 20000 Hz
- In-Cord Volume Control
- SoundGuard Technology
Microphone
- Boom
- Form Factor
- Headset microphone
- 100 - 8000 Hz
- Noise Cancelling
Remote Control
- Controls
- Connector Type
- USB (4 PIN USB Type A) , Headphones (mini-phone stereo 3.5 mm)
- Included Accessories
- Carrying case
- Cable Details
- Headset cable
- Limited warranty - 2 years
