Poly Blackwire C5220 Stereo USB-A Wired Headset
Quicklinx: FZJTWS00 Mfr#: 207576-201
Recommended Use: Computer
Connectivity: Wired
Earcover : Binaural
Hurry, only 1 left in stock!
£71.13 ex VAT
£85.35 inc VAT
Express delivery Order within the next 7 hours for delivery on Monday
The Blackwire 5200 Series fits your busy workday. Ergonomically designed, it's comfortable enough to wear all day, on your longest calls. The Blackwire 5200 Series - the power to connect and work easily is here.
Poly Blackwire C5220 USB-A - headset - USB, 3.5 mm jack
Headset - wired - USB, 3.5 mm jack
Recommended Use
Computer - communication
Headphones Form Factor
On-ear
Wired
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 20000 Hz
Microphone
Boom
Microphone Noise Cancelling
Controls
Mute, volume, answer/end
Series
5200 Series
20.9 cm
5.5 cm
18.6 cm
164.2 g
Headband Material
Cushioned metal
Earpad Material
Leatherette
Recommended Use
Voice alerts
Protection
Hearing protection
Audio Output
On-ear
Wired
Sound Output Mode
Stereo
Frequency Response
20 - 20000 Hz
In-Cord Volume Control
SoundGuard Technology
Microphone
Boom
Headset microphone
Frequency Response
100 - 8000 Hz
Noise Cancelling
Remote Control
Controls
Connector Type
USB (4 PIN USB Type A) , Headphones (mini-phone stereo 3.5 mm)
Carrying case
Cable Details
Headset cable
Connectivity: Wired
Earcover : Binaural
Brand: Poly
Stock Status: While stocks last
Stock Status: Clearance
