The Blackwire 3200 Series provides a quality audio experience in a headset that's built for enterprise needs. With a sleek design and flexible microphone boom for a customizable fit, what's not to love?
Enhanced call quality
Dynamic EQ optimizes the quality of your voice on calls, and automatically adjusts the EQ settings when you want high-quality sound for listening to music or for multimedia playback. -
Connectivity options
Select the right option for your device: USB-A or USB Type-C for PC and 3.5 mm for mobile connectivity with select models. -
Wearing style
Monaural wearing style for those who prefer to leave one ear open. -
Lightweight design
A lightweight metal headband offers durability and a comfortable custom fit. -
Simple call management
Use the intuitive inline controls to answer/end calls, control volume, and mute to simplify call management. Conveniently placed indicator lights provide helpful but unobtrusive user call, mute, and volume status. -
Optimized for communications platforms
An IT manager's dream, this headset was created for communication and is optimized and certified to work with top virtual meeting providers.
- Poly Blackwire 3215 - headset - USB-A, 3.5 mm jack
- Product Type
- Headset - wired - USB-A, 3.5 mm jack
- Compatibility
- Mac, Windows
- Recommended Use
- Portable electronics, computer
- Black
- Headphones Form Factor
- On-ear monaural
- Connectivity Technology
- Wired
- Audio Specifications
- Sensitivity 90 dB
- Impedance
- 32 Ohm
- Microphone
- Boom
- Microphone Operation Mode
- Omni-directional
- Controls
- Mute, volume, answer/end, hold, redial
- Software Certification
- Skype Certified, Cisco Jabber Certified, Avaya Certified
- Product Type
- Series
- Blackwire 3200 Series
- Compatibility
- Mac, Windows
- 15.5 cm
- 3.2 cm
- 17.8 cm
- 64 g
- Black
- Earpad Material
- Artificial leather
- Recommended Use
- Voice alerts
- Packaging Type
- Bulk
Audio Output
- On-ear monaural
- Wired
- Sensitivity
- 90 dB
- Impedance
- 32 Ohm
- Max Sound Pressure
- 118 dB
- Diaphragm
- 28 mm
- In-Cord Volume Control
- Adjustable Headband
- Dynamic EQ optimised, digital signal processing
Microphone
- Boom
- Omni-directional
- Sensitivity
- -38 dBV/Pascal
- Frequency Response
- 100 - 10000 Hz
Remote Control
- Controls
- Connector Type
- USB (USB Type-A) , Headphones (mini-phone 3.5mm)
- Cable Details
- USB-A cable
- Supported Host Device OS
- Windows 11, Windows 10, macOS
- Shipping Width
- 18.5 cm
- Shipping Depth
- 5.6 cm
- Shipping Height
- 20.7 cm
- Shipping Weight
- 250 g
Poly Headset Splitter - Y-type training cable for Poly Blackwire 5200 | In Stock | £12.79 |
Poly Headset Cable - M22 to Quick Disconnect for Poly M22 | In Stock | £10.68 |
Poly Spare Ear Cushion Foam for C310 & C320 | In Stock | £2.62 |
Poly HIS Adapter Cable | In Stock | £24.71 |
Poly Quick Disconnect to Quick Disconnect Extension Cable - 3m | In Stock | £8.76 |
Poly - USB adapter - USB to 24 pin USB-C | In Stock | £13.01 |
Poly - USB adapter - 24 pin USB-C to USB | In Stock | £12.95 |
Poly Spare Foam Ear Cushion BW3310 BW3320 | In Stock | £2.67 |
