Is background noise affecting your productivity? Reduce noise and increase focus with the Poly Blackwire 8225 headset with a noise-canceling microphone enhanced with Acoustic Fence technology and advanced hybrid active noise canceling (ANC).
Advanced hybrid ANC
Optimize audio comfort and quality with advanced hybrid active noise canceling (ANC) by choosing between three settings. -
Reduce disruptions from close talkers and environmental noise with the flexible, noise-canceling microphone enhanced with Acoustic Fence technology. -
Connectivity options
Allows greater flexibility of use by offering choices: USB-A or USB Type-C ?. -
Lightweight design
Padded headband and soft leatherette ear cushions provide all-day comfort. -
Inline control
Easy-to-use inline call control with call answer / end, mute, volume up / down buttons and a three-setting ANC switch. -
Communications platforms
An IT manager's dream, this headset was created for communication and is optimized and certified to work with top virtual meeting providers.
- Poly Blackwire 8225 - headset
- Product Type
- Headset - wired - USB-A
- Recommended Use
- Phone, computer
- Black
- Headphones Form Factor
- On-ear
- Connectivity Technology
- Wired
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 20 - 20000 Hz - Sensitivity 84 dB +/- 3dB
- Signal-To-Noise Ratio
- 118 dB
- Active Noise Canceling
- Microphone
- Boom
- Microphone Operation Mode
- Omni-directional
- Microphone Noise Cancelling
- Controls
- Mute, volume, answer/end, ANC mode
- Software Certification
- Zoom Certified
- Compatible Software
- Zoom
- 2-year warranty
- Product Type
- 15.5 cm
- 3.2 cm
- 17.8 cm
- 144 g
- Black
- Earpad Material
- Artificial leather
- Recommended Use
- Phone, computer
- 280° rotatable microphone, 2 LED indicators, boom mic length 135mm
Audio Output
- On-ear
- Wired
- Sound Output Mode
- Stereo
- Active Noise Cancelling Technology
- Advanced Hybrid Active Noise Cancellation
- 20 - 20000 Hz
- 118 dB
- Sensitivity
- 84 dB +/- 3dB
- Max Sound Pressure
- 118 dB
- Diaphragm
- 32 mm
- SoundGuard DIGITAL Technology, Acoustic Fence technology, Dynamic EQ optimised
Microphone
- Boom
- Omni-directional
- Sensitivity
- -38 dB
- 100 - 10000 Hz
- Noise Cancelling
- Noise Cancelling Technology
- Echo Noise Cancelling
Remote Control
- Controls
Cable
- Cable Length
- 2.19 m
- Supported Host Device OS
- Windows 10, macOS
- Zoom Certified
- Zoom
- Limited warranty - 2 years
- Shipping Width
- 18.3 cm
- Shipping Depth
- 20.9 cm
- Shipping Height
- 5.5 cm
- Shipping Weight
- 332 g
Poly Headset Splitter - Y-type training cable for Poly Blackwire 5200 | In Stock | £13.42 |
Poly Headset Splitter - Y-type training cable for Poly EncorePro | In Stock | £24.71 |
Poly Audio Cable - M22 to Quick Disconnect for Poly EncorePro | In Stock | £10.99 |
Poly DA75 Sound Card | In Stock | £32.13 |
Poly Headset Cable - M22 to Quick Disconnect for Poly M22 | In Stock | £10.64 |
Poly Spare Ear Cushion Foam for C310 & C320 | In Stock | £2.82 |
