Brand
Poly Blackwire 8225 USB-A
Quicklinx: G1CGWS00 Mfr#: 214406-01
Connectivity: Wired
£115.65 ex VAT
£138.78 inc VAT
Keep noise out and productivity up, no matter where you are working with the Blackwire 8225. Create a zone of calm so you can stay focused. Get your voice across and not the noise around.
  • Advanced hybrid ANC
    With four microphones and three ANC settings users can adjust the level of ANC to suite their current work location.
  • Ideal for all-day use
    Comfort, padded headband and soft leatherette ear cushions provide all-day comfort.
  • Acoustic fence technology
    Acoustic fence technology uses a noise canceling microphone and an additional omnidirectional microphone to ensure the users voice is the only thing heard and not the background noise.
Poly Blackwire 8225 - headset
Headset - wired - USB-A
Headphones Form Factor
On-ear
Wired
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 84 dB
Impedance
32 Ohm
Active Noise Canceling
Microphone
Boom
Microphone Noise Cancelling
Controls
Mute, volume, answer/end
Software Certification
Zoom Certified
186 g
Audio Output
On-ear
Wired
Active Noise Cancelling Technology
Hybrid ANC
Frequency Response
20 - 20000 Hz
Sensitivity
84 dB
Impedance
32 Ohm
Diaphragm
32 mm
Adjustable Headband
SoundGuard DIGITAL Technology
Microphone
Boom
Sensitivity
-35 dBV/Pascal
Frequency Response
100 - 10000 Hz
Noise Cancelling
Remote Control
Controls
Connector Type
Headset (4 PIN USB Type A)
Cable
Cable Length
2.2 m
Cable Details
Headset cable - 2.2 m
Zoom Certified
Connectivity: Wired
Brand: Poly
