Is background noise affecting your productivity? Reduce noise and increase focus with the Poly Blackwire 8225 headset with a noise-canceling microphone enhanced with Acoustic Fence technology and advanced hybrid active noise canceling (ANC).
Sound like a winner
With the Blackwire 8225, your voice is the only thing heard, not the chaos around you. Its noise-canceling microphone with Acoustic Fence technology puts you in a quiet office, even if you're in a noisy kitchen. -
Stay focused
It's no secret that tuning out background noise makes you more productive. Hybrid active noise canceling (ANC) makes it easy to escape the noise around you. And three ANC settings mean you can fine-tune your level of quiet where you work. -
Long-lasting comfort
The Blackwire 8225 is crafted from premium materials with a lightweight design. You will get a comfortable, customized fit using adjustment markers and 180° pivoting speakers. You'll fall in love with the aesthetic design and robust look and feel. -
Advanced hybrid ANC
Optimize audio comfort and quality with advanced hybrid active noise canceling (ANC) by choosing between three settings. -
Reduce disruptions from close talkers and environmental noise with the flexible, noise-canceling microphone enhanced with Acoustic Fence technology. -
Connectivity options
Allows greater flexibility of use by USB Type-C. -
Lightweight design
Padded headband and soft leatherette ear cushions provide all-day comfort. -
Inline control
Easy-to-use inline call control with call answer / end, mute, volume up / down buttons and a three-setting ANC switch. -
Communications platforms
An IT manager's dream, this headset was created for communication and is optimized and certified to work with good virtual meeting providers.
 - Poly Blackwire 8225 - headset - USB-C
- Product Type
 - Headset - wired - USB-C
- Compatibility
 - Mac, Windows
- Recommended Use
 - Computer, phone
 - Black
- Headphones Form Factor
 - On-ear
- Connectivity Technology
 - Wired
- Sound Output Mode
 - Stereo
- Audio Specifications
 - Sensitivity 84 dB +/- 3dB
- Impedance
 - 32 Ohm
- Signal-To-Noise Ratio
 - 118 dB
- Active Noise Canceling
- Microphone
 - Boom
- Microphone Operation Mode
 - Omni-directional
- Microphone Noise Cancelling
- Controls
 - Answer/end, mute, volume, ANC on/off
- Software Certification
 - Certified for Microsoft Teams, UC certified
- Product Type
- Series
 - Blackwire 8200 series
- Compatibility
 - Mac, Windows
 - 15.5 cm
 - 3.2 cm
 - 18.034 cm
 - 186 g
 - Black
- Earpad Material
 - Artificial leather
- Recommended Use
 - Computer, phone
 - 280° rotatable microphone, boom mic length 135mm
Audio Output
 - On-ear
 - Wired
- Sound Output Mode
 - Stereo
- Active Noise Cancelling Technology
 - Hybrid Active Noise Cancelling
 - 118 dB
- Sensitivity
 - 84 dB +/- 3dB
- Impedance
 - 32 Ohm
- Diaphragm
 - 32 mm
- In-Cord Volume Control
- Adjustable Headband
 - Echo reduction, Dynamic EQ optimised, Acoustic Fence technology, SoundGuard DIGITAL Technology
Microphone
 - Boom
 - Omni-directional
- Sensitivity
 - -38 dBV/Pascal
- Frequency Response
 - 100 - 10000 Hz
- Noise Cancelling
Remote Control
- Controls
- Connector Type
 - USB (24 pin USB-C)
- Included Accessories
 - Carrying case, USB-C to USB-A adapter
- Supported Host Device OS
 - Windows 10, macOS
- Shipping Width
 - 18.3 cm
- Shipping Depth
 - 20.9 cm
- Shipping Height
 - 5.5 cm
- Shipping Weight
 - 333 g
                        Poly Quick Disconnect to Quick Disconnect Extension Cable - 3m | In Stock | £8.85 |
                        Poly - USB adapter - USB to 24 pin USB-C | In Stock | £13.11 |
                        Poly - USB adapter - 24 pin USB-C to USB | In Stock | £12.95 |
