Poly Blackwire 8225 Stereo Microsoft Teams Certified USB-C
Quicklinx: HN3ZWS00 Mfr#: 8X225AA
Recommended Use: Phone, Computer, Phone
Connectivity: Wired
24 In Stock
£108.13 ex VAT
£129.75 inc VAT
Is background noise affecting your productivity? Reduce noise and increase focus with the Poly Blackwire 8225 headset with a noise-canceling microphone enhanced with Acoustic Fence technology and advanced hybrid active noise canceling (ANC).
  • Sound like a winner
    With the Blackwire 8225, your voice is the only thing heard, not the chaos around you. Its noise-canceling microphone with Acoustic Fence technology puts you in a quiet office, even if you're in a noisy kitchen.
  • Stay focused
    It's no secret that tuning out background noise makes you more productive. Hybrid active noise canceling (ANC) makes it easy to escape the noise around you. And three ANC settings mean you can fine-tune your level of quiet where you work.
  • Long-lasting comfort
    The Blackwire 8225 is crafted from premium materials with a lightweight design. You will get a comfortable, customized fit using adjustment markers and 180° pivoting speakers. You'll fall in love with the aesthetic design and robust look and feel.
  • Advanced hybrid ANC
    Optimize audio comfort and quality with advanced hybrid active noise canceling (ANC) by choosing between three settings.
  • Acoustic Fence technology
    Reduce disruptions from close talkers and environmental noise with the flexible, noise-canceling microphone enhanced with Acoustic Fence technology.
  • Connectivity options
    Allows greater flexibility of use by USB Type-C.
  • Lightweight design
    Padded headband and soft leatherette ear cushions provide all-day comfort.
  • Inline control
    Easy-to-use inline call control with call answer / end, mute, volume up / down buttons and a three-setting ANC switch.
  • Communications platforms
    An IT manager's dream, this headset was created for communication and is optimized and certified to work with good virtual meeting providers.
Poly Blackwire 8225 - headset - USB-C
Headset - wired - USB-C
Compatibility
Mac, Windows
Recommended Use
Computer, phone
Headphones Form Factor
On-ear
Wired
Sound Output Mode
Stereo
Audio Specifications
Sensitivity 84 dB +/- 3dB
Impedance
32 Ohm
Signal-To-Noise Ratio
118 dB
Active Noise Canceling
Microphone
Boom
Microphone Operation Mode
Omni-directional
Microphone Noise Cancelling
Controls
Answer/end, mute, volume, ANC on/off
Software Certification
Certified for Microsoft Teams, UC certified
Series
Blackwire 8200 series
Compatibility
Mac, Windows
15.5 cm
3.2 cm
18.034 cm
186 g
Earpad Material
Artificial leather
Recommended Use
Computer, phone
280° rotatable microphone, boom mic length 135mm
Audio Output
On-ear
Wired
Sound Output Mode
Stereo
Active Noise Cancelling Technology
Hybrid Active Noise Cancelling
118 dB
Sensitivity
84 dB +/- 3dB
Impedance
32 Ohm
Diaphragm
32 mm
In-Cord Volume Control
Adjustable Headband
Echo reduction, Dynamic EQ optimised, Acoustic Fence technology, SoundGuard DIGITAL Technology
Microphone
Boom
Omni-directional
Sensitivity
-38 dBV/Pascal
Frequency Response
100 - 10000 Hz
Noise Cancelling
Remote Control
Controls
Connector Type
USB (24 pin USB-C)
Carrying case, USB-C to USB-A adapter
Supported Host Device OS
Windows 10, macOS
Shipping Width
18.3 cm
Shipping Depth
20.9 cm
Shipping Height
5.5 cm
Shipping Weight
333 g
HN3Z Poly Headset Splitter - Y-type training cable for Poly Blackwire 5200 In Stock £13.58
HN3Z Poly - USB adapter - USB to 24 pin USB-C In Stock £13.30
HN3Z Poly - USB adapter - 24 pin USB-C to USB In Stock £13.04
Recommended Use: Computer
Connectivity: Wired
Brand: Poly
