Poly Blackwire 8225-M On-Ear Wired Headset
Quicklinx: HKG6WS00 Mfr#: 772K3AA
Recommended Use: Portable electronics, Computer
Connectivity: Wired
Earcover : Binaural
£137.96 ex VAT
£165.55 inc VAT
Is background noise affecting your productivity? Reduce noise and increase focus with the Poly Blackwire 8225 headset with a noise-canceling microphone enhanced with Acoustic Fence technology and advanced hybrid active noise canceling (ANC).
  • Advanced hybrid ANC
    Optimize audio comfort and quality with advanced hybrid active noise canceling (ANC) by choosing between three settings.
  • Acoustic Fence technology
    Reduce disruptions from close talkers and environmental noise with the flexible, noise canceling microphone enhanced with Acoustic Fence technology.
  • Connectivity options
    Allows greater flexibility of use by offering choices: USB-A or USB Type-C ?.
  • Lightweight design
    Padded headband and soft leatherette ear cushions provide all day comfort.
  • Inline control
    Easy-to-use inline call control with call answer / end, mute, volume up / down buttons and a three-setting ANC switch.
  • Certified for Microsoft Teams
    Full Microsoft Teams certification takes your Microsoft Teams experience to the next level with a button for instant access to the app and more.
Poly Blackwire 8225-M - headset - USB-A
Headset - wired - USB-A
Compatibility
Mac, Windows
Recommended Use
Computer, portable electronics
Headphones Form Factor
On-ear binaural
Wired
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 84 dB
Impedance
32 Ohm
Signal-To-Noise Ratio
118 dB
Microphone
Boom
Microphone Operation Mode
Omni-directional
Controls
Answer/end, mute, volume
Software Certification
Series
Blackwire 8200 series
Compatibility
Mac, Windows
15.5 cm
3.2 cm
17.8 cm
185 g
Earpad Material
Artificial leather
Recommended Use
Audio Output
On-ear binaural
Wired
Sound Output Mode
Stereo
Frequency Response
20 - 20000 Hz
118 dB
Sensitivity
84 dB
Impedance
32 Ohm
Max Sound Pressure
118 dB
Diaphragm
32 mm
In-Cord Volume Control
Dynamic EQ optimised
Microphone
Boom
Omni-directional
Sensitivity
-38 dB
Frequency Response
100 - 10000 Hz
Remote Control
Controls
Connector Type
USB (4 PIN USB Type A)
Supported Host Device OS
Windows 10, macOS
Shipping Width
18.3 cm
Shipping Depth
20.9 cm
Shipping Height
5.5 cm
Shipping Weight
332 g
HKG6 Poly Headset Splitter - Y-type training cable for Poly EncorePro In Stock £25.08
HKG6 Poly Headset Cable - M22 to Quick Disconnect for Poly M22 In Stock £10.80
HKG6 Poly Spare Ear Cushion Foam for C310 & C320 In Stock £2.69
HKG6 Poly HIS Adapter Cable In Stock £15.68
HKG6 Poly Quick Disconnect to Quick Disconnect Extension Cable - 3m In Stock £8.85
HKG6 Poly - USB adapter - USB to 24 pin USB-C In Stock £13.11
HKG6 Poly - USB adapter - 24 pin USB-C to USB In Stock £12.95
Recommended Use: Computer
Connectivity: Wired
Earcover : Binaural
Brand: Poly
