Poly Blackwire 5220 USB-C HS +USB-C/A Headset
Quicklinx: JCWSWS00 Mfr#: 8X231A6
More than 50 In Stock
£63.33 ex VAT
£75.99 inc VAT
The Blackwire 5200 Series fits your busy workday. Ergonomically designed for long lasting comfort. And with the easy-to-use connectivity you can work on a variety of devices throughout the day.
Poly Blackwire 5220 - headset - USB-C, 3.5 mm jack
Headset - wired - USB-C, 3.5 mm jack
Compatibility
Mac, Windows
Recommended Use
Portable electronics, computer
Headphones Form Factor
On-ear binaural
Wired
Sound Output Mode
Stereo
Audio Specifications
Sensitivity 116 dB
Impedance
32 Ohm
Signal-To-Noise Ratio
118 dB
Microphone
Boom
Microphone Noise Cancelling
Controls
Answer/end, mute, volume
Software Certification
Certified for Skype for Business, Cisco Jabber Certified, Avaya Certified, Certified for Microsoft Teams, Zoom Certified, UC certified, Works With Chromebook Certified
Compatibility
Mac, Windows
165.2 g
Earpad Material
Artificial leather
Recommended Use
280° rotatable microphone
Audio Output
On-ear binaural
Wired
Sound Output Mode
Stereo
118 dB
Sensitivity
116 dB
Impedance
32 Ohm
Diaphragm
32 mm
In-Cord Volume Control
Dynamic EQ optimised
Microphone
Boom
Sensitivity
-38 dBV/Pascal
Frequency Response
100 - 10000 Hz
Noise Cancelling
Remote Control
Controls
Connector Type
USB (24 pin USB-C) ¦ Headphones (mini-phone 3.5mm)
Carrying case, USB-C to USB-A adapter
Supported Host Device OS
Windows 10, macOS
JCWS Poly - USB adapter - 24 pin USB-C to USB In Stock £13.36
Brand: Poly
