The Blackwire 5200 Series fits your busy workday. Ergonomically designed for long lasting comfort. And with the easy-to-use connectivity you can work on a variety of devices throughout the day.
Connectivity options
Enhanced connectivity for your devices: USB-C cord with tethered USB-A adapter for PC and 3.5 mm for mobile or tablet connectivity. -
Comfort and durability
Ultra-soft leatherette ear cushion(s) wrapped around pillow-soft memory foam provide long lasting comfort. A lightweight cushioned metal headband offers durability and a comfortable custom fit. -
Wearing style
Premium PC wideband audio with noise-cancelling microphone and Digital Signal Processing (DSP) for a more natural voice sound. -
Simple call management
Use the intuitive inline controls to answer/end calls, control volume, and mute to simplify call management. Conveniently placed indicator lights provide helpful but unobtrusive user call, mute, and volume status. -
SoundGuard Digital technology provides advance audio protection
Premium PC wideband audio with noise-canceling microphone and Digital Signal Processing (DSP) for a more natural voice sound. -
Enhanced call quality
Dynamic EQ optimizes the quality of your voice on calls, and automatically adjusts the EQ settings when you want high-quality sound for listening to music or for multimedia playback.
- HP Poly Blackwire 5220 - headset - USB-C, 3.5 mm jack, USB-A
- Product Type
- Headset - wired - USB-C, 3.5 mm jack, USB-A
- Compatibility
- Mac, Windows
- Recommended Use
- Portable electronics, computer
- Black
- Headphones Form Factor
- On-ear binaural
- Connectivity Technology
- Wired
- Sound Output Mode
- Stereo
- Audio Specifications
- Sensitivity 116 dB
- Impedance
- 32 ohm
- Signal-To-Noise Ratio
- 118 dB
- Microphone
- Boom
- Microphone Noise Cancelling
- Controls
- Answer/end, mute, volume
- Software Certification
- Certified for Skype for Business, Cisco Jabber Certified, Avaya Certified, Certified for Microsoft Teams, Zoom Certified, UC certified, Works With Chromebook Certified
- Product Type
- Compatibility
- Mac, Windows
- 165.2 g
- Black
- Earpad Material
- Artificial leather
- Recommended Use
- 280° rotatable microphone
Audio Output
- On-ear binaural
- Wired
- Sound Output Mode
- Stereo
- 118 dB
- Sensitivity
- 116 dB
- Impedance
- 32 ohm
- Diaphragm
- 32 mm
- In-Cord Volume Control
- Dynamic EQ optimised
Microphone
- Boom
- Sensitivity
- -38 dBV/Pascal
- Frequency Response
- 100 - 10000 Hz
- Noise Cancelling
Remote Control
- Controls
- Connector Type
- USB (24 pin USB-C) ¦ Headphones (mini-phone 3.5mm)
- Included Accessories
- Carrying case, USB-C to USB-A adapter
- Supported Host Device OS
- Windows 10, macOS
Poly Headset Splitter - Y-type training cable for Poly Blackwire 5200 | In Stock | £13.58 |
Poly - USB adapter - USB to 24 pin USB-C | In Stock | £13.30 |
Poly - USB adapter - 24 pin USB-C to USB | In Stock | £13.36 |
