The Blackwire 5200 Series fits your busy workday. Ergonomically designed for long lasting comfort. And with the easy-to-use connectivity you can work on a variety of devices throughout the day.
Connectivity options
Enhanced connectivity for your devices: USB-C cord with tethered USB-A adapter for PC and 3.5 mm for mobile or tablet connectivity. -
Comfort and durability
Ultra-soft leatherette ear cushion(s) wrapped around pillow-soft memory foam provide long lasting comfort. A lightweight cushioned metal headband offers durability and a comfortable custom fit. -
Wearing style
Premium PC wideband audio with noise-cancelling microphone and Digital Signal Processing (DSP) for a more natural voice sound. -
Simple call management
Use the intuitive inline controls to answer/end calls, control volume, and mute to simplify call management. Conveniently placed indicator lights provide helpful but unobtrusive user call, mute, and volume status. -
SoundGuard Digital technology provides advance audio protection
Premium PC wideband audio with noise-canceling microphone and Digital Signal Processing (DSP) for a more natural voice sound. -
Enhanced call quality
Dynamic EQ optimizes the quality of your voice on calls, and automatically adjusts the EQ settings when you want high-quality sound for listening to music or for multimedia playback.
 - Poly Blackwire 5220 - headset - USB-C, 3.5 mm jack
- Product Type
 - Headset - wired - USB-C, 3.5 mm jack
- Compatibility
 - Mac, Windows
- Recommended Use
 - Portable electronics, computer
 - Black
- Headphones Form Factor
 - On-ear binaural
- Connectivity Technology
 - Wired
- Sound Output Mode
 - Stereo
- Audio Specifications
 - Sensitivity 116 dB
- Impedance
 - 32 Ohm
- Signal-To-Noise Ratio
 - 118 dB
- Microphone
 - Boom
- Microphone Noise Cancelling
- Controls
 - Answer/end, mute, volume
- Software Certification
 - Certified for Skype for Business, Cisco Jabber Certified, Avaya Certified, Certified for Microsoft Teams, Zoom Certified, UC certified, Works With Chromebook Certified
- Product Type
- Compatibility
 - Mac, Windows
 - 165.2 g
 - Black
- Earpad Material
 - Artificial leather
- Recommended Use
 - 280° rotatable microphone
Audio Output
 - On-ear binaural
 - Wired
- Sound Output Mode
 - Stereo
 - 118 dB
- Sensitivity
 - 116 dB
- Impedance
 - 32 Ohm
- Diaphragm
 - 32 mm
- In-Cord Volume Control
 - Dynamic EQ optimised
Microphone
 - Boom
- Sensitivity
 - -38 dBV/Pascal
- Frequency Response
 - 100 - 10000 Hz
- Noise Cancelling
Remote Control
- Controls
- Connector Type
 - USB (24 pin USB-C) , Headphones (mini-phone 3.5mm)
- Included Accessories
 - Carrying case, USB-C to USB-A adapter
- Supported Host Device OS
 - Windows 10, macOS
                        Poly Quick Disconnect to Quick Disconnect Extension Cable - 3m | In Stock | £8.85 |
                        Poly - USB adapter - USB to 24 pin USB-C | In Stock | £13.11 |
                        Poly - USB adapter - 24 pin USB-C to USB | In Stock | £12.95 |
