The Blackwire 5200 Series fits your busy workday. Ergonomically designed for long lasting comfort. And with the easy-to-use connectivity you can work on a variety of devices throughout the day.
Connectivity options
Select the right option for your device: USB-A or USB Type-C for PC and 3.5 mm for mobile connectivity. -
Comfort and durability
Ultra-soft leatherette ear cushion(s) wrapped around pillow-soft memory foam provide long lasting comfort. A lightweight cushioned metal headband offers durability and a comfortable custom fit. -
Wearing style
Hi-fi stereo wearing style for those who want a richer, more immersive experience. -
Simple call management
Use the intuitive inline controls to answer/end calls, control volume, and mute to simplify call management. Conveniently placed indicator lights provide helpful but unobtrusive user call, mute, and volume status. -
Outstanding audio quality
Premium PC wideband audio with noise-canceling microphone and Digital Signal Processing (DSP) for a more natural voice sound. -
Enhanced call quality
Dynamic EQ optimizes the quality of your voice on calls, and automatically adjusts the EQ settings when you want high-quality sound for listening to music or for multimedia playback.
- Poly Blackwire 5220 - headset
- Product Type
- Headset - wired - 3.5 mm jack, USB-A
- Compatibility
- Mac, Windows
- Recommended Use
- Portable electronics, computer
- Black
- Headphones Form Factor
- On-ear
- Connectivity Technology
- Wired
- Sound Output Mode
- Stereo
- Audio Specifications
- Sensitivity 90 dB
- Impedance
- 32 Ohm
- Microphone
- Boom
- Controls
- Mute, volume, answer/end
- Software Certification
- Certified for Skype for Business, Certified for Microsoft Teams, Avaya Certified, Cisco Jabber Certified
- Product Type
- Series
- Blackwire 5200 series
- Compatibility
- Mac, Windows
- Black
- Earpad Material
- Artificial leather
- Recommended Use
Audio Output
- On-ear
- Wired
- Sound Output Mode
- Stereo
- Sensitivity
- 90 dB
- Impedance
- 32 Ohm
- Diaphragm
- 28 mm
- In-Cord Volume Control
- Adjustable Headband
- Digital signal processing, Dynamic EQ optimised
Microphone
- Boom
- Sensitivity
- -38 dB
- Frequency Response
- 100 - 10000 Hz
Remote Control
- Controls
- Connector Type
- USB (4 PIN USB Type A) , Headphones (mini-phone 3.5mm)
- Included Accessories
- Carrying case
- Supported Host Device OS
- macOS, Windows
Poly Headset Splitter - Y-type training cable for Poly Blackwire 5200 | In Stock | £13.42 |
Poly Headset Splitter - Y-type training cable for Poly EncorePro | In Stock | £25.89 |
Poly Audio Cable - M22 to Quick Disconnect for Poly EncorePro | In Stock | £10.99 |
Poly DA75 Sound Card | In Stock | £32.13 |
Poly Spare Ear Cushion Foam for C310 & C320 | In Stock | £2.82 |
Poly HIS Adapter Cable | In Stock | £24.71 |
