Poly Blackwire 5220 Stereo USB-A On-Ear Wired Headset
Quicklinx: HK33WS00 Mfr#: 80R97AA
Recommended Use: Portable electronics, Computer
Connectivity: Wired
Earcover : Binaural
£44.20 ex VAT
£53.04 inc VAT
The Blackwire 5200 Series fits your busy workday. Ergonomically designed for long lasting comfort. And with the easy-to-use connectivity you can work on a variety of devices throughout the day.
  • Connectivity options
    Select the right option for your device: USB-A or USB Type-C for PC and 3.5 mm for mobile connectivity.
  • Comfort and durability
    Ultra-soft leatherette ear cushion(s) wrapped around pillow-soft memory foam provide long lasting comfort. A lightweight cushioned metal headband offers durability and a comfortable custom fit.
  • Wearing style
    Hi-fi stereo wearing style for those who want a richer, more immersive experience.
  • Simple call management
    Use the intuitive inline controls to answer/end calls, control volume, and mute to simplify call management. Conveniently placed indicator lights provide helpful but unobtrusive user call, mute, and volume status.
  • Outstanding audio quality
    Premium PC wideband audio with noise-canceling microphone and Digital Signal Processing (DSP) for a more natural voice sound.
  • Enhanced call quality
    Dynamic EQ optimizes the quality of your voice on calls, and automatically adjusts the EQ settings when you want high-quality sound for listening to music or for multimedia playback.
Poly Blackwire 5220 - headset
Headset - wired - USB-A, 3.5 mm jack
Compatibility
Mac, Windows
Recommended Use
Computer, portable electronics
Headphones Form Factor
On-ear
Wired
Sound Output Mode
Stereo
Audio Specifications
Sensitivity 90 dB
Impedance
32 Ohm
Microphone
Boom
Controls
Answer/end, mute, volume
Software Certification
Certified for Microsoft Teams, Certified for Skype for Business, Cisco Jabber Certified, Avaya Certified
Series
Blackwire 5200 series
Compatibility
Mac, Windows
Earpad Material
Artificial leather
Recommended Use
Audio Output
On-ear
Wired
Sound Output Mode
Stereo
Sensitivity
90 dB
Impedance
32 Ohm
Diaphragm
28 mm
In-Cord Volume Control
Adjustable Headband
Dynamic EQ optimised, digital signal processing
Microphone
Boom
Sensitivity
-38 dB
Frequency Response
100 - 10000 Hz
Remote Control
Controls
Connector Type
USB (4 PIN USB Type A) , Headphones (mini-phone 3.5mm)
Carrying case
Supported Host Device OS
Windows, macOS
HK33 Poly Headset Splitter - Y-type training cable for Poly Blackwire 5200 In Stock £12.98
HK33 Poly Headset Splitter - Y-type training cable for Poly EncorePro In Stock £24.25
HK33 Poly DA75 Sound Card In Stock £25.28
HK33 Poly Headset Splitter - Y-Type Training Cable In Stock £22.24
HK33 Poly Headset Cable - M22 to Quick Disconnect for Poly M22 In Stock £10.53
HK33 Poly HIS Adapter Cable In Stock £24.19
HK33 Poly Quick Disconnect to Quick Disconnect Extension Cable - 3m In Stock £8.64
HK33 Poly - USB adapter - USB to 24 pin USB-C In Stock £12.86
HK33 Poly - USB adapter - 24 pin USB-C to USB In Stock £12.95
Recommended Use: Computer
Connectivity: Wired
Earcover : Binaural
Brand: Poly
