Poly Blackwire 5220 C5220 USB-C Headset
Quicklinx: HM3DWS00 Mfr#: 805H3AA
Recommended Use: Computer, Portable electronics
Connectivity: Wired
Earcover : Monaural
£75.13 ex VAT
£90.15 inc VAT
The Blackwire 5200 Series fits your busy workday. Ergonomically designed for long lasting comfort. And with the easy-to-use connectivity you can work on a variety of devices throughout the day.
  • Connectivity options
    Select the right option for your device: USB-A or USB Type-C for PC and 3.5 mm for mobile connectivity.
  • Comfort and durability
    Ultra-soft leatherette ear cushion(s) wrapped around pillow-soft memory foam provide long lasting comfort. A lightweight cushioned metal headband offers durability and a comfortable custom fit.
  • Wearing style
    Hi-fi stereo wearing style for those who want a richer, more immersive experience.
  • Simple call management
    Use the intuitive inline controls to answer/end calls, control volume, and mute to simplify call management. Conveniently placed indicator lights provide helpful but unobtrusive user call, mute, and volume status.
  • Outstanding audio quality
    Premium PC wideband audio with noise-canceling microphone and Digital Signal Processing (DSP) for a more natural voice sound.
  • Enhanced call quality
    Dynamic EQ optimizes the quality of your voice on calls, and automatically adjusts the EQ settings when you want high-quality sound for listening to music or for multimedia playback.
Poly Blackwire C5220 - headset - USB-C, 3.5 mm jack
Headset - wired - USB-C, 3.5 mm jack
Compatibility
Mac, Windows
Recommended Use
Computer, portable electronics
Headphones Form Factor
On-ear
Wired
Sound Output Mode
Stereo
Audio Specifications
Sensitivity 90 dB
Impedance
32 Ohm
Microphone
Boom
Controls
Answer/end, mute, volume
Software Certification
Certified for Microsoft Teams, Certified for Skype for Business, Cisco Jabber Certified, Avaya Certified
Series
Blackwire 5200 series
Compatibility
Mac, Windows
164.2 g
Earpad Material
Artificial leather
Recommended Use
Audio Output
On-ear
Wired
Sound Output Mode
Stereo
Sensitivity
90 dB
Impedance
32 Ohm
Diaphragm
28 mm
In-Cord Volume Control
Adjustable Headband
Dynamic EQ optimised, digital signal processing
Microphone
Boom
Sensitivity
-38 dB
Frequency Response
100 - 10000 Hz
Remote Control
Controls
Connector Type
USB (24 pin USB-C) , Headphones (mini-phone 3.5mm)
Carrying case
Supported Host Device OS
Windows, macOS
HM3D Poly Headset Splitter - Y-type training cable for Poly Blackwire 5200 In Stock £12.79
HM3D Poly Headset Cable - M22 to Quick Disconnect for Poly M22 In Stock £10.68
HM3D Poly Spare Ear Cushion Foam for C310 & C320 In Stock £2.62
HM3D Poly HIS Adapter Cable In Stock £24.11
HM3D Poly Quick Disconnect to Quick Disconnect Extension Cable - 3m In Stock £8.76
HM3D Poly - USB adapter - USB to 24 pin USB-C In Stock £13.01
HM3D Poly - USB adapter - 24 pin USB-C to USB In Stock £12.95
HM3D Poly Spare Foam Ear Cushion BW3310 BW3320 In Stock £2.67
Recommended Use: Portable electronics
Connectivity: Wired
Earcover : Monaural
Brand: Poly
