The Blackwire 5200 Series fits your busy workday. Ergonomically designed, it's comfortable enough to wear all day, on your longest calls. The Blackwire 5200 Series - the power to connect and work easily is here.
Comfort and durability
Ideal for all-day use, long conference calls and listening to multimedia, the ultra-soft leatherette ear cushions wrapped around pillow-soft memory foam provide all-day comfort. -
Intuitive/user friendly features
One-touch call answer/end, volume+/-and mute with user friendly audio prompts and inline indicator lights alert the user to connection, mute and volume status. -
Plantronics signature audio
PC wideband audio with noise-canceling microphones for high-quality PC telephony plus Digital Signal Processing (DSP) provides natural voice sound whilst Plantronics patented technology provides advance audio protection and Dynamic EQ automatically adjusts audio settings between voice calls and music.
- Poly Blackwire C5220 USB-A - headset
- Product Type
- Headset - wired - USB, 3.5 mm jack
- Recommended Use
- Computer - communication
- Headphones Form Factor
- On-ear
- Connectivity Technology
- Wired
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 20 - 20000 Hz
- Microphone
- Boom
- Microphone Noise Cancelling
- Controls
- Mute, volume, answer/end
- 2-year warranty
- Product Type
- Series
- 5200 Series
- 20.9 cm
- 5.5 cm
- 18.6 cm
- 164.2 g
- Headband Material
- Cushioned metal
- Earpad Material
- Leatherette
- Recommended Use
- Voice alerts
- Protection
- Hearing protection
Audio Output
- On-ear
- Wired
- Sound Output Mode
- Stereo
- 20 - 20000 Hz
- In-Cord Volume Control
- SoundGuard Technology
Microphone
- Boom
- Form Factor
- Headset microphone
- 100 - 8000 Hz
- Noise Cancelling
Remote Control
- Controls
- Connector Type
- USB (4 PIN USB Type A) , Headphones (mini-phone stereo 3.5 mm)
- Included Accessories
- Carrying case
- Cable Details
- Headset cable
- Limited warranty - 2 years
