Poly Blackwire 5210 Monaural USB-C Headset +3.5mm Plug +USB-C/A Adapter
Quicklinx: HWLHWS00 Mfr#: 8X230AA
Recommended Use: Portable electronics, Phone, Computer, Phone
Connectivity: Wired
More than 50 In Stock
£52.80 ex VAT
£63.36 inc VAT
The Blackwire 5200 Series fits your busy workday. Ergonomically designed for long lasting comfort. And with the easy-to-use connectivity you can work on a variety of devices throughout the day.
  • Connectivity options
    Enhanced connectivity for your devices: USB-C cord with tethered USB-A adapter for PC and 3.5 mm for mobile or tablet connectivity.
  • Comfort and durability
    Ultra-soft leatherette ear cushion(s) wrapped around pillow-soft memory foam provide long lasting comfort. A lightweight cushioned metal headband offers durability and a comfortable custom fit.
  • Wearing style
    Monaural wearing style for those who prefer to leave one ear open.
  • Simple call management
    Use the intuitive inline controls to answer/end calls, control volume, and mute to simplify call management. Conveniently placed indicator lights provide helpful but unobtrusive user call, mute, and volume status.
  • Audio quality
    Premium PC wideband audio with noise-canceling microphone and Digital Signal Processing (DSP) for a more natural voice sound.
  • Enhanced call quality
    Dynamic EQ optimizes the quality of your voice on calls, and automatically adjusts the EQ settings when you want high-quality sound for listening to music or for multimedia playback.
Poly Blackwire 5210 - headset - 3.5 mm jack, USB-C
Headset - wired - 3.5 mm jack, USB-C
Compatibility
Mac, Windows
Recommended Use
Computer, phone, portable electronics
Additional Functions
SoundGuard DIGITAL
Headphones Form Factor
On-ear monaural
Wired
Sound Output Mode
Mono
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 6 dB RLR
Impedance
32 Ohm
Microphone
Boom
Microphone Operation Mode
Omni-directional
Microphone Noise Cancelling
Controls
Mute, volume, answer/end
Software Certification
Certified for Microsoft Teams, Certified for Skype for Business, Cisco Jabber Certified, Avaya Certified, Works With Chromebook Certified, Zoom Certified, UC certified
Series
Blackwire 5200 series
Compatibility
Mac, Windows
SoundGuard DIGITAL
165.2 g
Earpad Material
Artificial leather
Recommended Use
280° rotatable microphone
Audio Output
On-ear monaural
Wired
Sound Output Mode
Mono
Frequency Response
20 - 20000 Hz
Sensitivity
6 dB RLR
Impedance
32 Ohm
Diaphragm
32 mm
In-Cord Volume Control
Dynamic EQ optimised, echo reduction
Microphone
Boom
Omni-directional
Sensitivity
10 dB SLR
Frequency Response
100 - 10000 Hz
Noise Cancelling
Remote Control
Controls
Connector Type
USB (24 pin USB-C) , Headphones (mini-phone 3.5mm)
Software Included
Poly Lens
Carrying case, USB-C to USB-A adapter
Supported Host Device OS
Windows, macOS, iOS, Android
Shipping Weight
300 g
HWLH Poly Headset Splitter - Y-type training cable for Poly Blackwire 5200 In Stock £13.58
HWLH Poly - USB adapter - USB to 24 pin USB-C In Stock £13.30
HWLH Poly - USB adapter - 24 pin USB-C to USB In Stock £13.36
Recommended Use: Phone
Recommended Use: Computer
Connectivity: Wired
Brand: Poly
